Hi Adam,
I'm not sure this will help, but I created an iLogic routine some time ago which searched an Excel spreadsheet to populate the parameters to build an hydraulic cylinder. The parameters were used to modify 2 existing parts to the sizes required and also drove parameters in the assembly.
The data I used is from the APH Cylinders data sheet. The data runs in columns as opposed to rows as you ask.
I have attached a snippet of my data set for you to compare with the code.
Hopefully, by going through the code and comparing it to the data the code will make some sense and allow you to build your own routine.
Dim ExcelFile = "THIS WOULD BE THE LOCATION OF YOUR DATA SET\*****.xlsx"
i = GoExcel.FindRow(ExcelFile, "Sheet1", "Series", "=", Parameter("CylinderSeries"))
'Gather APH CYLINDER parameters from Excel spreadsheet and assign them to local variables
Rod = GoExcel.CurrentRowValue("Rod")
D3 = GoExcel.CurrentRowValue("D3")
D4 = GoExcel.CurrentRowValue("D4")
D6 = GoExcel.CurrentRowValue("D6")
D7 = GoExcel.CurrentRowValue("D7")
L1 = GoExcel.CurrentRowValue("L1")
L2 = GoExcel.CurrentRowValue("L2")
L3 = GoExcel.CurrentRowValue("L3")
L4 = GoExcel.CurrentRowValue("L4")
L5 = GoExcel.CurrentRowValue("L5")
L6 = GoExcel.CurrentRowValue("L6")
L7 = GoExcel.CurrentRowValue("L7")
L8 = GoExcel.CurrentRowValue("L8")
L9 = GoExcel.CurrentRowValue("L9")
L10 = GoExcel.CurrentRowValue("L10")
L11 = GoExcel.CurrentRowValue("L11")
L12 = GoExcel.CurrentRowValue("L12")
L13 = GoExcel.CurrentRowValue("L13")
L14 = GoExcel.CurrentRowValue("L14")
Stroke = Parameter("Stroke") 'Local parameter
' Cylinder Body Details
Parameter("Body.ipt", "CylBodyDia") = D3
Parameter("Body.ipt", "EyeWidth") = L11
Parameter("Body.ipt", "EyeThickness") = L9
Parameter("Body.ipt", "SwivelEyePos") = L12
Parameter("Body.ipt", "SwivelEyeDiameter") = D7
Parameter("Body.ipt", "OverBall") = L10
Parameter("Body.ipt", "SwivelHoleDia") = D4
Parameter("Body.ipt", "PortPos1") = L7
Parameter("Body.ipt", "PortPitch") = L3
Parameter("Body.ipt", "PortHeight") = L8
Parameter("Body.ipt", "CylStroke") = Stroke
Parameter("Body.ipt", "BodyLength") = ((L14 + Stroke) - L6 - (2 * L12))
If Parameter("CylinderSeries") < 48
Feature.IsActive("Body.ipt", "Port Pattern") = False
Else
Feature.IsActive("Body.ipt", "Port Pattern") = True
End If
Parameter("Body.ipt", "BodyColour") = Parameter("CylColour")
' Cylinder Rod Details
Parameter("Rod.ipt", "RodDia") = Rod
Parameter("Rod.ipt", "RodLength") = Stroke + 50
Parameter("Rod.ipt", "EyeWidth") = L11
Parameter("Rod.ipt", "EyeThickness") = L9
Parameter("Rod.ipt", "SwivelEyePos") = L12
Parameter("Rod.ipt", "SwivelEyeDiameter") = D7
Parameter("Rod.ipt", "OverBall") = L10
Parameter("Rod.ipt", "SwivelHoleDia") = D4
Parameter("MinCentre") = Stroke + L14
Parameter("MaxCentre") = (Stroke*2) + L14
Parameter("Rod.ipt", "RodColour") = Parameter("CylColour")
InventorVb.DocumentUpdate()
iLogicVb.UpdateWhenDone = True
GoExcel.Close
Regards
Darren
