iLogic Event Trigger Not Working
matt_jlt
matt_jlt
I have a skeleton model type assembly and parts etc (The parts are driven by a "Master" Part file which is derived into each file).
In the assembly, I want to have it trigger a rule when a Custom Property / iProperty Changes. The property is linked to a parameter in the derived part.
Example
Part Number: "=<DerivedParam_1>"
The rule does not trigger when this value changes. But if i change the text manually it will trigger. I assume it is because the actual formula doesn't change, but the value it references does. Is there any way around this? My only other option is to have it update on save and that isn't the solution I want as I means the user will have press save to see any changes.
Thanks, Matt.
matt_jlt
Update on problem,
If i have any parameter in an assembly which is changed via an iLogic rule, the event trigger for run on "Any Model Parameter Change" will not run. It only runs if I manually change them.
This particular project i'm working on is Inventor 2012 Pro & Windows 7.
Any help would be great.
Regards, Matt.
