ilogic Event on mouse click
karolis.s
karolis.s
I am looking for solution to store hole diameter in variable and use it in INVENTOR CAM default properties.
So my question is: Is it possible to get diameter of hole with mouseclick event? I mean i want to click on hole in my partDocument and immediately get diameter of it.
WCrihfield
I'm not familiar with Inventor CAM, but try this iLogic code to retrieve the diameter.
Dim oPDoc As PartDocument = ThisApplication.ActiveDocument
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim oCM As CommandManager = ThisApplication.CommandManager
Dim oHole As Face = oCM.Pick(SelectionFilterEnum.kPartFaceCylindricalFilter, "Select the Cylindrical Face of the hole you want to retrieve the Diameter from.")
If oHole.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then
	Dim oCylinder As Cylinder = oHole.Geometry
	Dim oDia As Double = (oCylinder.Radius) * 2
	MsgBox("Diameter = " & oDia,vbInformation,"DIAMETER")
End If
'You could also store oDia as a Shared Variable to be able to use it in another rule.
Also, if you're just looking for a way to launch the Measure tool, you can try the following command.
ThisApplication.CommandManager.ControlDefinitions.Item("AppMeasureDistanceCmd").Execute
I hope this helps.
If this solves your problem, or answers your questions, please click 'Accept As Solution".
Or, if this helps you reach your goal, please click 'LIKES" 👍.
Here are a few of the ideas I like.
If you agree, please vote for them, so they might get implemented.
  • Options to format contents of MessageBox, InputBox, and InputListBox Click Here
  • Ability to fully constrain and dimension to the edjes of images within drawing title block sketches, SketchedSymbol sketches, other drawing sketches, and assembly sketches Click Here
  • Save section view status in DesignViewRepresentation, so it can be used in drawing view Click Here
  • Add SolidBodies folder to iLogic Rule Editor Model Tab Click Here
  • Convert all views to Raster before autosave stores to 'OldVersions' folder Click Here
Wesley Crihfield
(Not an Autodesk Employee)
