iLogic Event-Driven Rule: Cannot find a rule with the name"" (in the document <open document)
TYoung_Combi
Message 1 of 13
TYoung_Combi
EDITED TO ADD: It looks as if the rules lost their names during transition from 2020 software to 2023 software, causing this issue.
Since upgrading to Autodesk 2023 software last week, many of my users are getting the following error when closing an assembly:
"More Info" text:
System.ArgumentException: RunRule: Cannot find a rule with the name: "" (in the document TBSR0400002.01.iam).
   at Autodesk.iLogic.Core.RuleProcessing.RuleRunManager.RunRule(String ruleName, NameValueMap ruleArguments)
   at iLogic.EventsRuleRunner.RunListOfRules(Document doc, iLogicCentral central, InventorEventCode eventCodeA, IList`1 ruleNames)
As stated, this was not happening prior to the upgrade. What do I need to look for to stop this error from occurring?
Replies (12)
Message 2 of 13
JMGunnar
Any Event trigger ?
Best Regards Johan
Message 3 of 13
TYoung_Combi
@JMGunnar
There were two event triggers showing rules with no names. I removed those nameless rules, and that took care of the problem.
I am very curious as to why they popped up after the software upgrade...
Message 4 of 13
JMGunnar
Where did you remove the rule in "This Document" or All Documents ?
Johan
Message 5 of 13
TYoung_Combi
@JMGunnar I removed from 'This Document'.  The next time this happens, I will remove from 'All Documents'. Still curious as to why it happened after the software update.
Message 6 of 13
WCrihfield
Do you recall if the rule(s) it was supposed to run were internal/local rules or external rules?  Have you imported your iLogic Configuration settings from before the upgrade?  (Tools tab > Options panel (may have to expand it down) > iLogic Configuration)  In that 'Advanced iLogic Configuration' dialog, you can use the buttons at the bottom to [Export...] your settings from your previous version of Inventor, then use the [Import...] button to import those settings into your new version of Inventor.  Within those settings, it tells Inventor where to look for your external iLogic rules, and what file extension you are using for your external iLogic rule files (among other things).  It may not be finding your external rules right now.  Just a thought.
Wesley Crihfield
(Not an Autodesk Employee)
Message 7 of 13
WCrihfield
Also, just so you know, those Event Triggers settings are stored in two different places, depending on their scope.  The settings that are to effect 'All Documents, 'All Parts', 'All Assemblies', or 'All Drawings' are stored in an external XML file.  And the settings that are to effect just 'This Document' are stored in a hidden iProperty set, within the document itself.  We have been able to access that hidden property set since back around 2012-13, by discovery, not by design, but users accessing it and using it by code, instead of through the user interface dialog, is not recommended by Autodesk.  If you can't get this fixed through normal means, or by simple settings changes, and it is a widespread problem, we may be able to create a batch type iLogic solution for helping to clean some of that up.
Wesley Crihfield
Message 8 of 13
JMGunnar
If only this file the error occurs
I have no direct answer.  /
more then soultion i have too remove rule from This Document event.
/ as @WCrihfield  writes .
"all documents"  controll external rules.
and have nothing with This document event.
if error occurs on many files  in  again, you update this post.
Best Regards Johan G
Message 9 of 13
TYoung_Combi
Our documents have one particular rule that is fired with a "New Document", "Before Save Document", and "Close Document". Somehow, two of the three occurrences had their rules' names disappear and they appear as a blank rule under the Event Triggers and interestingly enough, it didn't happen with ALL our files; it only sporadically affected files.
I appreciate everyone's feedback on this issue.
Message 10 of 13
JMGunnar
problems that occur sporadically
are usually the most difficult to put your finger on
1.do the files consist of ipart / iassembly
2.does it occur in copy design vault ?
3.what do the rules do ?
4.in which version was the file created that causes problems or does it happen in new files as well
@TYoung_Combi
Message 11 of 13
maxim.teleguz
ill just leave this here, it is a FIPS error. Policy change that the workplace did.
This implementation is not part of the Windows Platform FIPS validated cryptographic algorithms when...
Message 12 of 13
Sumit_ChauhanNZXE4
Community Visitor
Community Visitor
how to remove
Message 13 of 13
JMGunnar
Best JM Gunnar @Sumit_ChauhanNZXE4
