iLogic Error in getting assembly component defination
i have the following code,
SyntaxEditor Code Snippet
'On Error Resume Next Dim oDoc As Document oDoc = ThisApplication.ActiveDocument If oDoc.DocumentType <> kAssemblyDocumentObject Then Exit Sub End If 'MsgBox (odoc.documenttype) Dim oDef As AssemblyComponentDefinition oDef = oDoc.ComponentDefinition
when i run the above code, following error pops up,
Error in rule: iAssembly-GenerateMember, in document: iAssembly.iam
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
System.Runtime.InteropServices.COMException (0x80020003): Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
can some help me to solve this.
Thanks in advance,
Sanjay
Sanjay
