iLogic Error in getting assembly component defination
sanjaysy
sanjaysy
i have the following code,
SyntaxEditor Code Snippet
    'On Error Resume Next
    Dim oDoc As Document
    oDoc = ThisApplication.ActiveDocument
    If oDoc.DocumentType <> kAssemblyDocumentObject Then
        Exit Sub
    End If
    'MsgBox (odoc.documenttype)
    Dim oDef As AssemblyComponentDefinition
    oDef = oDoc.ComponentDefinition
when i run the above code, following error pops up,
Error in rule: iAssembly-GenerateMember, in document: iAssembly.iam
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
System.Runtime.InteropServices.COMException (0x80020003): Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
can some help me to solve this.
Thanks in advance,
Sanjay
Sanjay
LishuangLu
Did you encounter this issue with other assemblies?
The code runs well in my side with both assembly and iAssembly files.
If this only relates with typical iassembly, could you share that file with me for more investigation?
-Lisa
