iLogic DXF
iLogic DXF
iLogic DXF
Hallo Zusammen,
anbei habe ich ein eine Logic die speichert mir aus einer Baugruppe alle Blech in einen bestimmten Ordner.
Die Namen der DXF ist der Dateiname, ich möchte gerne vorne noch eine benutzerdefinierte variable aus den iProperties anhängen.
<PF_PRT_ZNR> vor dem Dateinamen.
Die DXF soll dann heissen "Zeichnungsnummer + Dateiname"
Der Code:
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
End If
'get user input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
End If
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslation​Context
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMa​p
'get DXF target folder path
oFolder = oPath & "\" & oAsmName & " DXF Files"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Component - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has been saved
For Each oRefDoc In oRefDocs
iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
'check that model is saved
If(System.IO.File.Exists(iptPathName)) Then
Dim oDrawDoc As PartDocument
oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
Try
'Set the DXF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & ".dxf"
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDrawDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
End If
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PR​OFILE"
oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
'just for check its works coretcly
'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
'MessageBox.Show(i,"title",MessageBoxButtons.OK)
'If i=2 Then
'Exit Sub
'End If
oCompDef.FlatPattern.ExitEdit
Catch
End Try
oDrawDoc.Close
Else
End If
Next
MFG
Sascha May
S_May
Exit Sub
End If
'get user input
& vbLf & " " _
Return
Else
End If
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
End If
Try
Try
CustomName =iProperties.Value(oFileName, "Custom", "PF_PRT_ZNR")
Catch
CustomName ="XXX" 'Wert, wenn iPropertie PF_PRT_ZNR nicht existiert
End Try
oDataMedium.FileName = oFolder & "\" & CustomName  & " " & oFileName & ".dxf"
oCompDef.Unfold
Else
End If
Dim sOut As String
'If i=2 Then
'Exit Sub
'End If
Catch
End Try
oDrawDoc.Close
Else
End If
Next
