iLogic Drawing View File Type Identification
Message 1 of 10
I'm trying to identify the file subtype of a selected drawing view using an iLogic rule (I want to perform further operations on the model referenced by the drawing view, but only if it references an assembly).
I know it will be some version of this code: http://inventortrenches.blogspot.ca/2013/03/determine-file-type-for-ilogic-rule.html
but my programming skills are far too rookie. Can someone help?
Replies (9)
Message 2 of 10
chrisw01a
Hey, I am trying to do this and I cannot figure it out.  Can someone shed some light on this please?
It is not picking up something because it puts the same string on parts and assemblies.
See red text in the code below.
'iterate through a IDW and add "Part Number, Total Part Qty" to the base view labels
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oModel = ThisDoc.ModelDocument
Dim oSheets As Sheets = oDoc.Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
For Each oSheet In oSheets
	oViews = oSheet.DrawingViews
	For Each oView In oViews
		'oView.ViewType = DrawingViewTypeEnum.kDetailDrawingViewType _
		'oView.ViewType = DrawingViewTypeEnum.kSectionDrawingViewType
		If oView.ViewType = DrawingViewTypeEnum.kStandardDrawingViewType Then
		'if viel label is hidden, unhide
		oView.ShowLabel = True
			Try
			'get the property ID for these custom iProperties from the model referenced by the view
			o_iPropID_1 = oModel.PropertySets.Item("User Defined Properties").Item("TotalPartQty").PropId
			o_iPropID_2 = oModel.PropertySets.Item("User Defined Properties").Item("My_iProp_2").PropId
			Catch
			'here you could add a message that one or more of the custom iProperties were not found
			End Try
			Try
			'format the custom iproperty string and add the property ID
			oPartQty = "<Property Document='model' PropertySet='User Defined Properties' " _
			& "Property='TotalPartQty' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='" _
			& o_iPropID_1 & "'>TotalPartQty</Property>"
			''format the custom iproperty string and add the property ID
			'oString2 = "<Property Document='model' PropertySet='User Defined Properties' " _
			'& "Property='My_iProp_2' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='" _
			'& o_iPropID_2 & "'>My_iProp_2</Property>"
			'format the built in iproperty string and add the property ID
			oPartNumber = "<StyleOverride Bold='false' Underline='false'><Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property></StyleOverride>"
			'oStockNumber = "<Br/><StyleOverride Bold='false' Underline='false'><Property Document='model' PropertySet='Design Tracking Properties' Property='Stock Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>STOCK NUMBER</Property></StyleOverride>"
			'oStringScale = "<StyleOverride FontSize='0.2'> FLAT VIEW (<DrawingViewScale/>)</StyleOverride>"
			'oPartNumber = "<Br/><StyleOverride Underline='False' FontSize='0.2'>PART ID:    <Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property></StyleOverride>"
			'oStringProfile = "<Br/><StyleOverride FontSize='0.2'>PROFILE:   <Property Document='model' PropertySet='Design Tracking Properties' Property='Description' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property></StyleOverride>"
			oStringMaterial = "<StyleOverride Underline='False'><Property Document='model' PropertySet='Design Tracking Properties' Property='Material' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='20'>PART NUMBER</Property></StyleOverride>"
			'oStringAuth = "<Br/><StyleOverride Underline='False' FontSize='0.2'>QTY:        <Property Document='model' PropertySet='Design Tracking Properties' Property='Authority' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>AUTHORITY</Property></StyleOverride>"
				'add the custom iproperties to the view label
				'oView.Label.FormattedText = "<DrawingViewName/><Br/>" & oString1 & oString2
				'Here Is a list Of all Of the the DocumentType enumerators available In the API:
				'kUnknownDocumentObject
				'kPartDocumentObject
				'kAssemblyDocumentObject
				'kDrawingDocumentObject
				'kPresentationDocumentObject
				'kDesignElementDocumentObject
				'kForeignModelDocumentObject
				'kSATFileDocumentObject
				'kNoDocument
				'DETERMINE MODEL TYPE
				If oModel.DocumentType = kPartDocumentObject  Then
				oView.Label.FormattedText = oPartNumber & "<Br/>" & oStringMaterial & "<Br/>" & oPartQty & " RQD "
				Else
				oView.Label.FormattedText = oPartNumber & "<Br/>" & oPartQty & " RQD "
			Catch
			'do nothing if error
			End Try
	Next
Next
Message 3 of 10
Hi can you explain a bit further what your workflow would be, are you hoping to run the rule then select a drawing view to query? Are there numerous model references on the one drawing?
I generally only have one model reference on my drawings and use this to determine its document type:
If ThisDoc.ModelDocument Is Nothing Then
MsgBox("There is no referenced model in document")
Exit Sub
If ThisDoc.ModelDocument.DocumentType = kAssemblyDocumentObject Then
MsgBox("The referenced model is an assembly")
' Do something with the assembly
Else
MsgBox("The referenced model is not an assembly")
Message 4 of 10
@chrisw01a your If statement is querying oModel, if you have more than one model referenced on your drawing, oModel will be the view that was placed first (see image attached)
Message 5 of 10
chrisw01a
I have multiple sheets and multiple views per sheet.  I need to iterate through the views (which the code is already doing) and determine if the model is of the part type or assembly type.
Thank you
Chris
Message 6 of 10
To query the model referenced by a certain view, you will need to declare a new variable that gets the referenced model of that view:
Dim oViewModelDoc As Document
Set oViewModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
Message 7 of 10
chrisw01a
Rule Compile Errors in IDW Add View Label, in -A.idw
Error on Line 15 : 'Let' and 'Set' assignment statements are no longer supported.
Message 8 of 10
Sorry that was in VBA, this should work for you:
'***** START OF CODE *****
Dim oSheet As Sheet
Try
Catch
End Try
Try
'kNoDocument
If oViewModelDoc.DocumentType = kPartDocumentObject Then
Else
Catch
End Try
Next
Next
Message 9 of 10
chrisw01a
At any rate, I have this working now.
Thank you very much.  And thank to the others that replied as well.
Have a great week!
Chris
Message 10 of 10
chrisw01a
After looking at this,  I don't know how it was functioning to begin with since "oModel" was declared globally...
