iLogic Drawing Box
iLogic Drawing Box
Cosmin_V
iLogic Drawing Box
Cosmin_V
I have a Assembly whit iLogic rules. And we use to types of template for drawing. In one, for drawing box is use "CMA_Prod" template for Drawing box and "CUN_Idw_Styret" in the others.
The problem is, if i open the Assembly on the drawing whit  template "CMA_Prod" Is ok but if I open it in the drawing whit  template "CUN_Idw_Styret" then I can't se nothing in drawing box because this is set to be edit only manual.
Can be there a rule which is change the "CUN_Idw_Styret" whit "CMA_Prod" when I open this Assembly in drawing?
johnsonshiue
Hi! Do you mind sharing the example files here? Either it is a bug or there is something wrong with the rules.
Many thanks!
Software Test Engineer
Cosmin_V
Hi.
This are the Templates I work whit...If I open the assembly in CMA templates the iProperties of the assembly is appear in drawing box, but if I open it in CUN is not.
And I would like to change the "CUN_Idw_Styret" and "CUN_Idw_portrait" from CUN templates whit "CMA_Prod" from CMA templates
johnsonshiue
Hi! I think you want to transfer the borders from drawing A to drawing B, right? If yes, you can use a standalone tool installed with Inventor. Go to All Programs -> Autodesk Inventor 20xx -> Tools -> Drawing Resource Transfer Wizard. You can select the source drawing and select the particular resource. Then push it to selected drawings. Please try it and see if it works for you.
Many thanks!
Cosmin_V
hi,
Not the border but the Title blocks. It vase in the plan but my boss does not let me to change them.
So the problem is solve.
