iLogic Drawing Adding Sheets
The Goal is to add a sheet (with the DWG AP Template)and insert the Top View of the Part into the sheet. I can add the sheet but am unable to use the template I want. It comes in as a C Size Sheet. Doesn't help I have a Nasty Cold. Any Help would be appreciated. Thanks.
HermJan.Otterman
Hello Steve,
I'm not shure what you are asking.
if you can add a sheet, you already have a file open, why do you need a template?
If you have no file open then you need a template:
Private Sub CreateNewDrawingsFromTemplate()
Dim oDrawDoc As Inventor.DrawingDocument = Nothing
'open template
Try
oDrawDoc = Thisapplication.Documents.Open("DWG AP", True)
Catch ex As Exception
MsgBox("template file does not exist")
End Try
End Sub
when you add the sheet, you can specify the size
Syntax
Sheets.Add( [Size] As DrawingSheetSizeEnum, [Orientation] As PageOrientationTypeEnum, [SheetName] As String, [Width] As Variant, [Height] As Variant ) As Sheet
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
