ilogic detect/check if document/part has changed, then run code
Guido.LangeTuchscherer
Hi there,
I am looking for a way to read the (I am told it exists) property or filesetting flag which defines weather the document has been changed since the last save or not.
I would like to run my ilogic just before saving, but only when there has been a change to the document, as i run into other issues with the standard functinoality of Inventor and our Pdm-System Gain.
Thanks for your help in advance.
Greetings Guido L.-T.
JelteDeJong
You can add this to the top of your update rule
If ThisDoc.Document.Dirty = False Then
    Return
Jelte de Jong
Blog: hjalte.nl - github.com
Thanks alot @JelteDeJong,
this works perfectly for parts and I think i got it to run for the subparts of the assembly too.
fsdolphin
This seems to work for parts and assemblies.
Question.
Is it possible to get more details of what has changed?
Thanks a lot!
