Check out idw from Assembly
jzcrouse
jzcrouse
I have a code to run through every part in a assembly, open the associated idw, run a rule and close. It works great most of the time however if a user does not check out a drawing it will error out. Usually inventor will prompt to check out a drawing but sometimes the prompt does not happen and i get an error. There is probably something wrong with those specific drawings since there is no prompt but I need a work around. I need to force the drawings to check out when or before they open.
My thought would be to use the commandmanager command to check out but I cannot figure out how to run that in the drawing as the code errors out on the open command. "dwgdoc = ThisApplication.Documents.Open(Dwgname)"
Not sure if there is a way to open the document with options and check out that way
Imports System.IO.Path
Imports System.IO
Imports System.Collections
Imports System.Collections.ObjectModel
Private Sub Main()
Dim asmDoc As AssemblyDocument
If Not ThisApplication.ActiveDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
MessageBox.Show("Rule must be ran in assembly")
GoTo Line2
asmDoc = ThisDoc.Document
'initiate list to be used in sub
Dim needsdwg As New List(Of String)
' Call the function that traverses the assembly
Call Iterate( asmDoc.ComponentDefinition.Occurrences, 1, needsdwg)
Line2:
' Update the view.
End Sub
'passes a list of parameters and retains info between sub assemblies; byref passes actual parameter
Sub Iterate(ByRef Occurrences As ComponentOccurrences, ByVal Level As Integer, ByRef needsdwg As List(Of String))
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisDoc.Document.ComponentDefinition
Dim Parentasm As String = ThisAssembly.Document.DisplayName
Dim currentasm As String
Dim oPart As ComponentOccurrence
Dim oPartpath As String
Dim FNamePos As Long
Dim Part_Name As String
'counts the number of occurances in assembly
Dim updated As New List(Of String)
Dim count As Integer
count = ThisAssembly.Components.Count
'''Iterate through part occurrences in assembly
auto = iLogicVb.Automation
For Each oPart In Occurrences
Dim oFileName As String = oPart.Definition.Document.FullFileName
'Check to see if occurance is a Part
Dim partnumber As String = iProperties.Value(oPart.Name, "Project", "Part Number")
If needsdwg.Contains(partnumber)
GoTo line1
Else
needsdwg.add(partnumber)
If oPart.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oDoc As PartDocument = oPart.Definition.Document
Dim dtl As String = iProperties.Value(oPart.Name, "Custom", "ITS_DTL")
If dtl.Contains("Y") Then
FNamePos = InStrRev(oFileName, "\", -1)
Part_Name = Right(oFileName, Len(oFileName) -FNamePos)
oPartpath = Left(oFileName, Len(oFileName) -Len(Part_Name))
'sets full file name to search for, drawing must be in same folder as part.
Dim Dwgname As String = oPartpath & "\" & partnumber & ".idw"
'check to see if drawing file exists
If System.IO.File.Exists(Dwgname) = True Then
Dim dwgdoc As DrawingDocument
auto.RunExternalRule(dwgdoc, "UPDATE_DRAWING_TITLEBLOCK")
dwgdoc.Save
dwgdoc.Close
Else
'Adds part names without a detail to list
' needsdwg.add(New dwgs(partnumber), partnumber)
Else
'ignore bolted assemblies.
ElseIf partnumber.Contains("Bolted")=True Then
GoTo line1
'recursively call sub to traverse through occurance if it is a subassembly
ElseIf oPart.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
Call Iterate( oPart.SubOccurrences, 1, needsdwg)
line1 :
Next
'finds if part being processes is in a sub or parent assembly
line2 :
End Sub
JelteDeJong
Checking out (and in) files is difficult in iLogic. I have seen posts in the past that did it by communicating  with the vault server. It has always been to dificult for me. But i understand that you only have occasionally have problems. There for you might consider to skip those problem files and just show a message box. you could do it like this:
    Try
        dwgdoc.Save()
        dwgdoc.Close()
    Catch ex As Exception
        MsgBox("Exception was thrown while updating file: " & Dwgname)
    End Try
Else
Jelte de Jong
Blog: hjalte.nl - github.com
