Ilogic Detail view label
ballnr
ballnr
Hi all
For my default detail view lable. Please see this picture.
Can I have ilogic to copy text become to this picture.
Please help.
A.Acheson
Hi @ballnr
You can do this in the style by adding a prefix to label name and removing "DETAIL" word from Display Text.
Here is the same process through ilogic.
Dim drawView As DetailDrawingView = ThisApplication.CommandManager.Pick(
                       				SelectionFilterEnum.kDrawingViewFilter,
                       				"Select a drawing view")
drawView.Name = "Detail " & drawView.Name
Dim formattedText As String = drawView.Label.FormattedText
drawView.Label.FormattedText = formattedText.Replace("DETAIL", "")
Regards
Alan
ballnr
Thank you for suggestion.
This is my first setting.
When I change setting to
I get the resault.
For your Ilogic, I get the resault.
But the "<VIEW IDENTIFIER>" is change to "Detail A".
Very diffical for me to change to same this picture.
Is it possible for Ilogic to change text format at
Change from
TO
Please help and suggest.
A.Acheson
In the style you can add the word "Detail" then hit space bar and you will end up with "Detail "
This will then end up with the label name looking like this Detail A.
I would avoid wrapping the Identifier with apostrophe like  "A" simply because you now can't set up the standard style to do this automatically. While it is possible to get this outcome with ilogic it would need to be made manually run  or run on save. Just send the formatted text to an inputbox or logger statement and recreate the formatted text string with the additional apostrophes.
Logger.Info(drawView.Label.FormattedText)
Regards
Alan
ballnr
Please help to generate Ilogic.
So sorry for my skill.
