Add Custom properties to all subassemblies and parts
kresh.bell
kresh.bell
I have iLogic for import project custom properties from xls which generated ERP system. It works ok. I use that iLogic in my top assembly. But I would like, if it's possible, when I import custom property in e.g. top assembly that all my subassemblies and parts also have this properties.
And one minor thing, is it possible after importing that iLogic generate message "All Custom Properties Successfully Imported"?
Dim odoc = ThisDoc.Document
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Spredsheet Files (*.xls) (*.xlsx) (*.xlsm) (*.xlsb)|*.xls; *.xlsx; *.xlsm; *.xlsb"
'Set open location using one of these 2 options below, "1)Hard coded" or "2)Project location":
'oFileDlg.InitialDirectory = "D:\INVENTOR DATA\PROJEKTI\"  'Hard Coded path:
oFileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
'Show File Open Dialogue
oFileDlg.DialogTitle = "Browse for XLS File"
oFileDlg.ShowOpen()
oXLfile = oFileDlg.FileName
If oXLfile = "" Then : Return : End If
iProperties.Value("Custom", "Referenced Spreadsheet File Name") = oXLfile
'Open Excel file
GoExcel.Open(oXLfile, "Job Sheet")
'Read from Excel file
iProperties.Value("Custom", "AreaCode") = GoExcel.CellValue("H4")
iProperties.Value("Custom", "AreaName") = GoExcel.CellValue("C4")
iProperties.Value("Custom", "ComponentCode") = GoExcel.CellValue("H7")
iProperties.Value("Custom", "ComponentName") = GoExcel.CellValue("C7")
iProperties.Value("Custom", "Priority") = GoExcel.CellValue("P7")
iProperties.Value("Custom", "D365WoNumber") = GoExcel.CellValue("H8")
iProperties.Value("Custom", "DWGName") = GoExcel.CellValue("C6")
iProperties.Value("Custom", "DWGRef") = GoExcel.CellValue("H6")
iProperties.Value("Custom", "FSCReg") = GoExcel.CellValue("N20")
iProperties.Value("Custom", "HealthSafetySheets") = GoExcel.CellValue("H19")
iProperties.Value("Custom", "IssuedTo") = GoExcel.CellValue("P6")
iProperties.Value("Custom", "ItemCode") = GoExcel.CellValue("H5")
iProperties.Value("Custom", "ItemName") = GoExcel.CellValue("C5")
iProperties.Value("Custom", "JobDescription") = GoExcel.CellValue("A9")
iProperties.Value("Custom", "LoadList") = GoExcel.CellValue("C20")
iProperties.Value("Custom", "Notes01") = GoExcel.CellValue("A10")
iProperties.Value("Custom", "Notes02") = GoExcel.CellValue("A11")
iProperties.Value("Custom", "Notes03") = GoExcel.CellValue("A12")
iProperties.Value("Custom", "Notes04") = GoExcel.CellValue("A13")
iProperties.Value("Custom", "Notes05") = GoExcel.CellValue("A14")
iProperties.Value("Custom", "Notes06") = GoExcel.CellValue("A15")
iProperties.Value("Custom", "Notes07") = GoExcel.CellValue("A16")
iProperties.Value("Custom", "Notes08") = GoExcel.CellValue("A17")
iProperties.Value("Custom", "Notes09") = GoExcel.CellValue("A18")
iProperties.Value("Custom", "ProjectCode") = GoExcel.CellValue("H3")
iProperties.Value("Custom", "Project_Name") = GoExcel.CellValue("C3")
iProperties.Value("Custom", "RefDrawing") = GoExcel.CellValue("C6")
iProperties.Value("Custom", "TehnicalDataSheets") = GoExcel.CellValue("P19")
iProperties.Value("Custom", "UnitQty1") = GoExcel.CellValue("A22")
iProperties.Value("Custom", "UnitQty2") = GoExcel.CellValue("A23")
iProperties.Value("Custom", "UnitQty3") = GoExcel.CellValue("A24")
iProperties.Value("Custom", "UnitName1") = GoExcel.CellValue("B22")
iProperties.Value("Custom", "UnitName2") = GoExcel.CellValue("B23")
iProperties.Value("Custom", "UnitName3") = GoExcel.CellValue("B24")
iProperties.Value("Custom", "UnitEmpty1") = GoExcel.CellValue("C22")
iProperties.Value("Custom", "UnitEmpty2") = GoExcel.CellValue("C23")
iProperties.Value("Custom", "UnitEmpty3") = GoExcel.CellValue("C24")
iProperties.Value("Custom", "UnitDescription1") = GoExcel.CellValue("D22")
iProperties.Value("Custom", "UnitDescription2") = GoExcel.CellValue("D23")
iProperties.Value("Custom", "UnitDescription3") = GoExcel.CellValue("D24")
'Close Excel file
GoExcel.Close
A.Acheson
Hi @kresh.bell
To do this you need a few things, target all the documents of the assembly through referenced documents. Next you need to target the iproperty in each document. The filename with extension is read using System.IO
Sub Main
	Dim fileDlg As Inventor.FileDialog = Nothing
	InventorVb.Application.CreateFileDialog(fileDlg)
	fileDlg.Filter = "Spredsheet Files (*.xls) (*.xlsx) (*.xlsm) (*.xlsb)|*.xls; *.xlsx; *.xlsm; *.xlsb"
	'fileDlg.InitialDirectory = "D:\INVENTOR DATA\PROJEKTI\"  'Hard Coded path:
	fileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
	fileDlg.DialogTitle = "Browse for XLS File"
	fileDlg.ShowOpen()
	Dim xlFile As String  = fileDlg.FileName
	If xlFile = "" Then : Exit Sub: End If
	'Open Excel file.
	GoExcel.Open(xlFile, "Job Sheet")
	Dim doc As Document = ThisDoc.Document
	Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(doc, "Custom Properties Import") 'Make this a single transaction
	Dim filename As String  = Nothing
	processDocument(filename,xlFile)
	If doc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		'Traverse all referenced documents.
		For Each refDoc As Document In doc.AllReferencedDocuments
			'Avoid readonly files like CC and Library.
			If refDoc.IsModifiable Then
				filename = IO.Path.GetFileName(refDoc.FullFileName)
		Next
	'Close Excel file.
	GoExcel.Close
	trans.End 'End the trasaction
	MessageBox.Show("All Custom Properties Successfully Imported", "iLogic")
End Sub
Sub processDocument(filename As String, xlFile As String)
	iProperties.Value(filename,"Custom", "Referenced Spreadsheet File Name") = xlFile
	iProperties.Value(filename,"Custom", "AreaCode") = GoExcel.CellValue("H4")
	iProperties.Value(filename,"Custom", "AreaName") = GoExcel.CellValue("C4")
	iProperties.Value(filename,"Custom", "ComponentCode") = GoExcel.CellValue("H7")
	iProperties.Value(filename,"Custom", "ComponentName") = GoExcel.CellValue("C7")
	iProperties.Value(filename,"Custom", "Priority") = GoExcel.CellValue("P7")
	iProperties.Value(filename,"Custom", "D365WoNumber") = GoExcel.CellValue("H8")
	iProperties.Value(filename,"Custom", "DWGName") = GoExcel.CellValue("C6")
	iProperties.Value(filename,"Custom", "DWGRef") = GoExcel.CellValue("H6")
	iProperties.Value(filename,"Custom", "FSCReg") = GoExcel.CellValue("N20")
	iProperties.Value(filename,"Custom", "HealthSafetySheets") = GoExcel.CellValue("H19")
	iProperties.Value(filename,"Custom", "IssuedTo") = GoExcel.CellValue("P6")
	iProperties.Value(filename,"Custom", "ItemCode") = GoExcel.CellValue("H5")
	iProperties.Value(filename,"Custom", "ItemName") = GoExcel.CellValue("C5")
	iProperties.Value(filename,"Custom", "JobDescription") = GoExcel.CellValue("A9")
	iProperties.Value(filename,"Custom", "LoadList") = GoExcel.CellValue("C20")
	iProperties.Value(filename,"Custom", "Notes01") = GoExcel.CellValue("A10")
	iProperties.Value(filename,"Custom", "Notes02") = GoExcel.CellValue("A11")
	iProperties.Value(filename,"Custom", "Notes03") = GoExcel.CellValue("A12")
	iProperties.Value(filename,"Custom", "Notes04") = GoExcel.CellValue("A13")
	iProperties.Value(filename,"Custom", "Notes05") = GoExcel.CellValue("A14")
	iProperties.Value(filename,"Custom", "Notes06") = GoExcel.CellValue("A15")
	iProperties.Value(filename,"Custom", "Notes07") = GoExcel.CellValue("A16")
	iProperties.Value(filename,"Custom", "Notes08") = GoExcel.CellValue("A17")
	iProperties.Value(filename,"Custom", "Notes09") = GoExcel.CellValue("A18")
	iProperties.Value(filename,"Custom", "ProjectCode") = GoExcel.CellValue("H3")
	iProperties.Value(filename,"Custom", "Project_Name") = GoExcel.CellValue("C3")
	iProperties.Value(filename,"Custom", "RefDrawing") = GoExcel.CellValue("C6")
	iProperties.Value(filename,"Custom", "TehnicalDataSheets") = GoExcel.CellValue("P19")
	iProperties.Value(filename,"Custom", "UnitQty1") = GoExcel.CellValue("A22")
	iProperties.Value(filename,"Custom", "UnitQty2") = GoExcel.CellValue("A23")
	iProperties.Value(filename,"Custom", "UnitQty3") = GoExcel.CellValue("A24")
	iProperties.Value(filename,"Custom", "UnitName1") = GoExcel.CellValue("B22")
	iProperties.Value(filename,"Custom", "UnitName2") = GoExcel.CellValue("B23")
	iProperties.Value(filename,"Custom", "UnitName3") = GoExcel.CellValue("B24")
	iProperties.Value(filename,"Custom", "UnitEmpty1") = GoExcel.CellValue("C22")
	iProperties.Value(filename,"Custom", "UnitEmpty2") = GoExcel.CellValue("C23")
	iProperties.Value(filename,"Custom", "UnitEmpty3") = GoExcel.CellValue("C24")
	iProperties.Value(filename,"Custom", "UnitDescription1") = GoExcel.CellValue("D22")
	iProperties.Value(filename,"Custom", "UnitDescription2") = GoExcel.CellValue("D23")
	iProperties.Value(filename,"Custom", "UnitDescription3") = GoExcel.CellValue("D24")
End Sub
Regards
Alan
kresh.bell
It works great, thanks
