iLogic - Delete Center Of Gravity symbols
Message 1 of 17
I would like a code to delete all Center Of Gravity symbols (only in active sheet).
Any suggestions? Thanks!
Replies (16)
Message 2 of 17
That should work:
Dim oDoc As Drawingdocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oCenterMark As Centermark
For Each oCenterMark In oSheet.Centermarks
	If oCenterMark.CenterMarkType = CentermarkTypeEnum.kCenterOfGravityCentermarkType Then
		oCenterMark.Delete
	End If
Next
Message 3 of 17
Stakin
Try this
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
	oSheet = oDrawingDoc.ActiveSheet
Dim CenterMark As Centermark
For Each CenterMark In oSheet.Centermarks
	If CenterMark.CentermarkType = Inventor.CentermarkTypeEnum.kCenterOfGravityCentermarkType Then
		CenterMark.Delete()
End If
Next
Before run the rule:
After run
Message 4 of 17
Hi, I mean this symbol. Maybe it is called something else than Center of gravity?
Message 5 of 17
This is Origin Indicator (for Ordinate Dimensions).
You can hide it:
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oView As DrawingView
For Each oView In oSheet.DrawingViews
	If oView.OriginIndicator Is Nothing
	Else
		oView.OriginIndicator.Visible = False
	End If
Next
Message 6 of 17
Hi tomasz
I tried this code, but symbol is still there after I run the code.
Message 7 of 17
Can you attach files?
Drawing and corresponding model?
Message 8 of 17
It is classified documents unfortunately. Thanks for your help. I will try to figure it out 🙂
Message 9 of 17
Can you show what happens when you right-click this symbol?
What appears?
Message 10 of 17
This: 
Message 11 of 17
It looks like a sketch. A symbol drawn in sketch of the view.
Try double-clicking on in - it should trigger sketch editing.
If so, we can delete all sketches but that can delete also other things.
Message 12 of 17
Yes, if I delete the sketch then the symbol will also be deleted.
Is it possible to code that all sketches with these symbols will be deleted?
Message 13 of 17
I don't think so.
Please edit this sketch and check what makes this symbol. Is it just circle, lines and filled region? Or maybe some block?
Message 14 of 17
WCrihfield
Is your drawing document a DWG or an IDW?  If it's a DWG, then is it possible that center of gravity object is an AutoCADBlock object?  If so, you may be able to use iLogic code similar to the following:
(Just change the name of the AutoCADBlock it is looking for within the code to match what yours is called.)
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Inventor.Sheet = oDDoc.ActiveSheet
For Each oABlock As AutoCADBlock In oSheet.AutoCADBlocks
	'<<<< CHANGE THIS NAME >>>>
	If oABlock.Name = "Center Of Gravity" Then
		oABlock.Delete
	End If
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
If you have time, please... Vote For My IDEAS 💡and Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
Message 15 of 17
In browser it looks like this: 
In sketch it looks like this, seems like it is a circle with lines, however I am not able to edit it:
Message 16 of 17
Is the name of this sketch always "Sketch1"?
Is deleting all sketches an option?
Message 17 of 17
tomasz: It's not always sketch 1. I guess I have to delete it manually then.
I would also like to remove the text and leader besides this symbol. I am able to delete the text but not the arrow. I described the issue in the last post here: https://forums.autodesk.com/t5/inventor-customization/ilogic-to-replace-letter-in-text-location-in-d...
