iLogic: Customizing occurrence name by adding Assembly PN
JreyesGQ5VQ
JreyesGQ5VQ
Hello all,
Just starting to incorporate iLogic to automate some workflows. I have a pretty good start from going through the forums, but need some help with one last detail.
My current code (attached) goes through all first-level items and renames them to the format 'PN - Description'. What I would also like to do is rename any second-level items if they have "- base" in their occurrence name to 'firstlevelPN - base'. The base part would essentially pull the PN of the assembly it is in. Essentially the ideal output would look something like below:
TopAssy
       > FirstLevelPN - Description
              > FirstLevelPN - base
Thanks in advance for any help
You should be able to add another For Each into your current one for sub occurrences and use the Part Number of the parent assembly. You seem to have a good grasp on how you want to name them, so I'm not going to write an entire block of code.
I'm not sure why you are using the browser node name instead of the ComponentOccurrence.Name, I don't know if there is a difference though.
Hopefully this is what you're looking for
Dim oOcc As ComponentOccurrence
For Each oOcc In oDoc.ComponentDefinition.Occurrences
......naming code.....
   For Each oSubOcc as ComponentOccurrence in oOcc.SubOccurrences
   ...naming code...
   oSubOcc.Name = invPartNumberProperty.Value & " - base"
   Next
Next
_dscholtes_
@JreyesGQ5VQ
I'm also curious why you change the browser node name instead of the ComponentOccurrence.Name
(I have even found an script that changes the Document.DisplayName in order to change the occurrence name.)
JreyesGQ5VQ
@Anonymous Thanks for the suggestion on adding another For Each. @_dscholtes_ I honestly copied this code from somewhere in the forum, and modified it to add description instead of just PN. So I don't exactly know why browser node names are used instead. My guess is it has something to do with the counter number?
Do you know what I can use to search the sub parts for " - base" in the current occurrence name? My intention is to only rename these.
Well if using the browser node works the way you want, I guess there is no reason to change it.
To check the Occurrence name is simple, just need a .Contains.
   If oSubOcc.Name.Contains(" - base") Then
     ...naming code...
   End If
   Next
Next
_dscholtes_
Put this in the For-Each oSubOcc loop:
If oSubOcc.Name Like "* - base*" Then
    <do your renaming here>
End If
or
If InStr(1, oSubOcc.Name, " - base") > 0 Then
End If
