iLogic created folders disappearing from model tree
mgrenier2
mgrenier2
I use this iLogic rule to create some model tree folders inside an assembly file :
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oPane As BrowserPane = oDoc.BrowserPanes.ActivePane
Dim oTopNode As BrowserNode = oPane.TopNode
Dim oFolder As BrowserFolder
Dim MyArrayList As New ArrayList
MyArrayList.Add("Boulonnerie")
MyArrayList.Add("Quincaillerie - Composantes achetées")
MyArrayList.Add("Plans, axes et Points")
For Each oVal In MyArrayList
    Try
	    oFolder = oTopNode.BrowserFolders.Item(oVal)
    Catch
        oFolder = oPane.AddBrowserFolder(oVal)
    End Try
Next
However whenever I drag/drop a part to the folder it justs disappear...
Any idea what could be going on?
Frederick_Law
No idea.
Works in IV2023.4
Assembly with parts: run rule, drag part into folder.
New Assembly: run rule, add part, drag into folder.
