ilogic create folder not working
andrew_canfield
Message 1 of 9
andrew_canfield
Hello
I've copied some code to create pdf's but the folder isn't being created.
(I've changed the path).
Copied out the folder code (as below)  - ideally i'd like all users to be able to output to their desktop areas.
No error messages are returned  - wondering what's happening?
oFolder = "%USERPROFILE%\Desktop\PDF"
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
Regards
Andrew
Replies (8)
Message 2 of 9
JhoelForshav
Hi @andrew_canfield
Does this work for you?
Dim oFolder = Environment.GetFolderPath(Environment.SpecialFolder.Desktop) & "\PDF"
End If
Message 3 of 9
andrew_canfield
Thankyou - the code works.
However when I transfer it back to the main body (original copied from
https://forums.autodesk.com/t5/inventor-customization/ilogic-auto-save-pdf/td-p/7427556:
my Frankenstein :
(top 5 lines commented out to save with defer updates on & then produce a pdf)
'Dim oDoc As Document'
'oDoc = ThisApplication.ActiveDocument'
''oValue = oDoc.DrawingSettings.DeferUpdates ()'
'oDoc.DrawingSettings.DeferUpdates = "True"'
'ThisDoc.Save
End If
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("project", "revision number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2'oOptions.Value("Custom_End_Sheet") = 4
End If
'get PDF target folder path
oFolder = "%USERPROFILE%\Desktop\pdf"
'Check for the PDF folder and create it if it does not exist
End If
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & _
" rev" & oRevNum & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------end of iLogic-------
Message 4 of 9
JhoelForshav
Try changing "Environment" to System.Environment 🙂
It's interpreted now as Inventor.Environment so you need to clearify
Dim oFolder = System.Environment.GetFolderPath(System.Environment.SpecialFolder.Desktop) & "\PDF"
End If
Message 5 of 9
andrew_canfield
just tried a manual save as pdf & see this (I started this thread thinking it would be fairly straight forward!) - apologies.
Message 6 of 9
JhoelForshav
That error message seems to be about some missing font?
What happens if you run the code like this?
'ThisDoc.Save
Dim oFolder As String = System.Environment.GetFolderPath(System.Environment.SpecialFolder.Desktop) & "\PDF"
End If
End If
'Publish document
Message 7 of 9
andrew_canfield
Message 8 of 9
andrew_canfield
but...when i run the code again
Message 9 of 9
andrew_canfield
working ok on a different drawing - will test some more.
thanks again
