ilogic - create drawing from part
liam.dewhurstNMKYG
Message 1 of 8
liam.dewhurstNMKYG
Hi Team,
The open drawing from part dialogue has now started digging down 5 layers deep in folders! Which now searches our entire projects folder for the drawing you haven't yet created (and locks up inventor for 10 minutes while it searches 40Gb...)
I found this code that checks in about 1 second for the drawing in the current folder which is fantastic
ThisApplication.Documents.Open(ThisDoc.PathAndFileName(True).Replace("ipt", "idw"))
However, I want to start the "create drawing" function if it doesn't find one. Currently it throws an error, so I think I can run a catch/throw function to insert a create drawing.
Does anyone know how to start the dialogue for create drawing? I've found automations (https://clintbrown.co.uk/2018/10/07/automatic-drawings-with-ilogic/)
but we have many different templates for customers so I don't want to automatically generate the drawing & place views etc.
I just want to open this dialogue here:
Replies (7)
Message 2 of 8
Curtis_Waguespack
Hi @liam.dewhurstNMKYG
For the issue of the open dialog hanging up, please check this setting, in your project file... if it is not set to no, then setting to no might resolve this issue... I can't recall, but I remember having this issue in the past with that Open Drawing option.
See this link for more explination:
https://forums.autodesk.com/t5/inventor-forum/using-unique-file-names-option/m-p/6008909#M590217
I hope this helps.
Curtis
Message 3 of 8
Curtis_Waguespack
As for creating a new drawing if the one isn't found, I'm not sure that we can access the create new view interfaces via automation, but something like this should get you started in creating the drawing.
I hope this helps.
Curtis
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Try
	ThisApplication.Documents.Open _
	Return 'exit rule
Catch
End Try
oNewDrawing = ThisDoc.ChangeExtension(".idw")
oTemplateFolder = ThisApplication.FileOptions.TemplatesPath
oTemplate = oTemplateFolder & "Standard.idw"
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.Documents.Add _
(DocumentTypeEnum.kDrawingDocumentObject, oTemplate, True)
oDrawingDoc.Activate()
Dim oSheet As Sheet
oSheet = oDrawingDoc.Sheets.Item(1)
Dim oPoint As Point2d
oPoint = ThisApplication.TransientGeometry.CreatePoint2d(10, 10)
Dim oView As DrawingView
oView = oSheet.DrawingViews.AddBaseView(oDoc, oPoint, 1, _
ViewOrientationTypeEnum.kFrontViewOrientation, _
DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle)
oDrawingDoc.SaveAs(oNewDrawing, False)
MessageBox.Show("This new file saved as: "& oNewDrawing, "iLogic")
Message 4 of 8
Curtis_Waguespack
Or maybe something like this since you mentioned you need to choose the template
	Imports System.IO
Try 'to open the drawing
	Return 'exit rule
Catch
End Try
'since nothing found create it...
Dim oList As New ArrayList
Dim Folder As New IO.DirectoryInfo(oTemplateFolder)
For Each File As IO.FileInfo In Folder.GetFiles("*.idw", IO.SearchOption.AllDirectories)
	Dim sName As New FileInfo(File.Name)
	oList.Add(sName.Name)
Next
oTemplate = InputListBox("Select a template", oList, oList(0),"iLogic", "List")
oTemplate = oTemplateFolder & oTemplate
Dim oSheet As Sheet
Message 5 of 8
liam.dewhurstNMKYG
Hey Curtis, Brilliant.
I chopped the save function off the end, but I'm running that one straight as is.
Thanks for your help!
Message 6 of 8
liam.dewhurstNMKYG
Hey Curtis -
Do you know how to get this running on an assembly? Currently throwing an error
I can change the PartDocument to an AssemblyDocument and it runs however I'm just not sure how to leave it looking for a part, but  catch the error and run as an Assembly Doc instead?
This feels like a simple thing - but it doesn't quite compute yet/
Imports System.IO
'change this to
Imports System.IO
Dim oDoc As AssemblyDocument
'But if I try to run two variables I get stuck in the Try loop
Dim oAsm As AssemblyDocument
Dim oDpc As PartDocument
oAsm = ThisApplication.ActiveDocument
	Return 'exit rule
Catch
	(ThisAsm.PathAndFileName(True).Replace("ipt", "idw"))
	Return 'exit rule
End Try
'I'm just not sure how to catch the failure and turn it into opening an assembly doc.
But..... I managed to get this & my other macros into buttons
#myfirstbutton
It's the small things in life that are really satisfying...
Message 7 of 8
Curtis_Waguespack
Maybe just something like this.
I hope this helps.
Curtis
Imports System.IO
Dim oDoc As Document
oExt = Right(oDoc.FullDocumentName,3) 'get file extension
	(ThisDoc.PathAndFileName(True).Replace(oExt, "idw"))
	Return 'exit rule
Catch
End Try
Next
oTemplate = InputListBox("Select a template", oList, oList(0), "iLogic", "List")
Logger.Info(oTemplate)
Dim oSheet As Sheet
Message 8 of 8
Zain_Zarar
How do I get it to select my default drawing template rather than listing ansi, bsi etc?
