Ilogic Copy of Sketched Symbol from template IDW to IDW
Message 1 of 9
I've searched the forum and seen several posts which were helpful, but I keep running into my own ignorance and can't quite get things to work.  There will be several ways to solve this, some more robust than others.  Right now I'd just like to get it working as simply as possible!
I want to have a template IDW containing sketched symbols representing various possible drawing status stamps; when the drawing is ready for publish I want to run a rule which allows selection of one stamp for insertion on the drawing.  For right now, I'm just interested in how to copy the symbol from the one drawing to the other.  Here is my nonworking code:
'Query stamp insertion requirement
question = MessageBox.Show("Do you want to insert a stamp?", "Stamp Requirement",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
	If question = vbYes Then
		Dim strSelectedStamp As String = "Result2"
		Dim strStampList As New ArrayList
		strStampRequired = True
		strStampList.Add("F&C Stamp Round")
		strStampList.Add("As-Built Stamp Round")
		strStampList.Add("Test")
		strSelectedStamp = InputListBox("Please select a stamp.", strStampList, strSelectedStamp, "Stamp Selection", "Available Stamps")
		Dim strDrawDoc As Inventor.DrawingDocument: strDrawingDoc = ThisApplication.ActiveDocument
		Dim SourceFile As String = "D:\Local Server\Data\Autodesk Customization\Templates\IV2014Stamps.idw"
		Dim strSourceIDW As DrawingDocument
		strSourceIDW = ThisApplication.Documents.Open(SourceFile, False)
		Dim symbolDef As SketchedSymbolDefinition
		For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions
			If (StrComp(symbolDef.Name,strSelectedStamp,vbTextCompare)=0)Then
				CopyFrom = symbolDef.CopyTo(strDrawDoc, True)
			End If
		Next
I get a 'The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))' error.  Any ideas what I am doing wrong and how to fix it?
Thanks for the help!
Replies (8)
Message 2 of 9
Mike.Wohletz
try this out and let me know if it is what you are looking for.
        question = MessageBox.Show("Do you want to insert a stamp?", "Stamp Requirement", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
            'strStampList.Add("F&C Stamp Round")
            'strStampList.Add("As-Built Stamp Round")
            'strStampList.Add("Test")
            'strSelectedStamp = InputListBox("Please select a stamp.", strStampList, strSelectedStamp, "Stamp Selection", "Available Stamps")
            Dim strDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
                strStampList.Add(symbolDef.Name)
            Next
                If (StrComp(symbolDef.Name, strSelectedStamp, vbTextCompare) = 0) Then
                End If
            Next
            strSourceIDW.Close()
        End If
Message 3 of 9
Thanks for that!  It worked beautifully, and better than I expected.  May I ask another question, or should I post under a new topic?
Later in my code I want to take the selected symbol and place it on a drawing sheet.  If I code in the symbol name where I show XXXXX below, it inserts the symbol as expected.  How do I get it to insert the selected symbol using a string/variable?
'Insert stamp if required
If strStampRequired = True Then
	Dim strDrawDoc As DrawingDocument = ThisDrawing.Document
	Dim strSketchedSymbolDef As SketchedSymbolDefinition = strDrawDoc.SketchedSymbolDefinitions.Item(XXXXX)
	Dim strTransGeom = ThisApplication.TransientGeometry
	Dim strInsertionPoint As Point2d = strTransGeom.CreatePoint2d(5.5,13)
	Dim strSketchedSymbol As SketchedSymbol = strSheet.SketchedSymbols.Add(strSketchedSymbolDef,strInsertionPoint,0,0.75,Nothing)
Else
End If
Any ideas how to fix it?  I thought I could substitute strSelectedStamp for the XXXXX, but that causes the earlier code to error with 'Variable 'strSelectedStamp' hides a variable in an enclosing block'  on the line 'Dim strSelectedStamp As String = "Result2".  I'd like to understand what I'm doing wrong...
Message 4 of 9
Mike.Wohletz
I think that something like this is what you are after. let me know if this is the proper solution to your question.
    Sub Main()
            Next
                    If MsgBox("Would you like to place the stamp on the drawing?", MsgBoxStyle.YesNo, "Insert Stamp") = MsgBoxResult.Yes Then
                        InsertSymbol(symbolDef.Name)
                    End If
                End If
            Next
        End If
    End Sub
    Private Sub InsertSymbol(ByVal SymbName As String)
        Dim strSheet As Sheet = strDrawDoc.ActiveSheet
        Dim strSketchedSymbolDef As SketchedSymbolDefinition = strDrawDoc.SketchedSymbolDefinitions.Item(SymbName)
        Dim strInsertionPoint As Point2d = strTransGeom.CreatePoint2d(5.5, 13)
        Dim strSketchedSymbol As SketchedSymbol = strSheet.SketchedSymbols.Add(strSketchedSymbolDef, strInsertionPoint, 0, 0.75, Nothing)
    End Sub
Message 5 of 9
Thanks again!  Your code runs perfectly as intended when I run it as its own rule.
Unfortunately, I am doing some things in between loading the symbol and placing it on the sheet.  I'll try to describe, rather than posting the whole rule as it is quite long and probably terrible.
We prefer to use multisheet IDWs.  The limiting factor historically has been a populated titleblock for each sheet: the file sizes and memory requirements were just too burdensome, so operationally had a macro which split the idw into individual IV.dwg sheets and then added the titleblock populated from a spreadsheet.  The spreadsheet is nice; it tracks our revision history for an entire document set.
Now we are trying something similar in iLogic, and my rule first specifies the border, titleblock, and stamp (which will be the same for all sheets) and then steps through each sheet adding the border, titleblock and stamp if required, populates the titleblock with custom iproperties read in from the spreadsheet, saves/exports the resultant to ACAD dwg and pdf, and then deletes the same from that sheet before continuing to the next sheet.  At any given time, the IDW custom iProperties contain sufficient data to populate only one sheet's titleblock.
Consequently, I'd like to call subInsertSymbol to the active sheet immediately before the sheet is exported, but if I move InsertSymbol(symbolDef.Name) it seems symbolDef becomes 'not declared'...at least that is the error I am getting.  Here is just a snip of the code showing the last of assigning values to the iProperties through to the start of publishing, all in Sub Main():
iProperties.Value("Custom", "PROJECTTITLE1-2") = strProjTitle2
iProperties.Value("Custom", "FILENUM2") = strFileNum2
iProperties.Value("Custom", "AREA/FACILITY") = strAreaFac
iProperties.Value("Custom", "DOC/TYPE") = strDocType
'Insert the border on the active sheet
ActiveSheet.Border = "HEL"
'Insert the titleblock on the active sheet
ActiveSheet.TitleBlock = strSelectedTB
	'Dim strDrawDoc As DrawingDocument = ThisDrawing.Document
	'Dim strSketchedSymbolDef As SketchedSymbolDefinition = strDrawDoc.SketchedSymbolDefinitions.Item(strSelectedStamp)
	'Dim strTransGeom = ThisApplication.TransientGeometry
	'Dim strInsertionPoint As Point2d = strTransGeom.CreatePoint2d(5.5,13)
	'Dim strSketchedSymbol As SketchedSymbol = strSheet.SketchedSymbols.Add(strSketchedSymbolDef,strInsertionPoint,0,0.75,Nothing)
Else
End If
MessageBox.Show("All properties have been applied to " & strCurrentSeqNum, "Title Block Data Status")
'---------------Export the sheet to pdf------------------------
'Assign path and file name
strFullFileName = strPdfFolder & "\" & strFileNum2 & ".pdf"
strPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
strDocument = ThisApplication.ActiveDocument
Am I declaring symbolDef in the wrong location for it to be available throughout?
Message 6 of 9
Here's the entire rule...I've put <snipped for length> where I've taken out repetitive data&colon;
Public Sub Main()
'Check if publish rule intentional
question = MessageBox.Show("Ready to commence publishing?", "Confirm Publish",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
	If question = vbNo Then
    Return
	Else
    End If
'Define pdf and dwg file locations
strPublishedFolder = ThisDoc.Path & "\Published"
'Make output folders if they don't exist
    strPdfFolder = strPublishedFolder & "\PDF"
    If Dir(strPdfFolder, vbDirectory) = "" Then MkDir (strPdfFolder)
    strDwgFolder = strPublishedFolder & "\DWG"
    If Dir(strDwgFolder, vbDirectory) = "" Then MkDir (strDwgFolder)
'Title block selection from external file
ThisDrawing.ResourceFileName = "D:\Local Server\Data\Autodesk Customization\Templates\IV2014TitleBlocks.idw"
ThisDrawing.KeepExtraResources = False
Dim strSelectedTB As String = "Result"
Dim strTitleBlock As New ArrayList
strTitleBlock.Add("EMAL")
strTitleBlock.Add("EmalP2")
strTitleBlock.Add("KMP")
strSelectedTB = InputListBox("Select a Title Block", strTitleBlock, strSelectedTB, "Title Block Selection", "Available Title Blocks")
        Next
            End If
        Next
		MessageBox.Show("You have selected " & strSelectedStamp, "Stamp Selection Feedback")
		Else
			strStampRequired = False
    End If
'Step through each sheet in the IDW
Dim strSheets As Sheets
strSheets = ThisDoc.Document.sheets
For Each strSheet In strSheets
	strSheet.activate
'Truncate the sheet instance from the sheet name, keeping the digits before the colon
SheetName = ActiveSheet.Name
ColonIndex = SheetName.LastindexOf(":")
strCurrentSeqNum = SheetName.substring(0,ColonIndex)
'Access the Titleblock Data spreadsheet and select the row corresponding to the active drawing sheet
i = GoExcel.FindRow("TBData.xlsx", "Sheet1", "SEQNO", "=", strCurrentSeqNum)
'Get the cell values for the designated row
strArea = GoExcel.CurrentRowValue("AREA")
strDocType = GoExcel.CurrentRowValue("DOC/TYPE")
'Populate the Custom iProperties with the TBData values
iProperties.Value("Custom", "AREA") = strArea
	Else
End If
strContext = ThisApplication.TransientObjects.CreateTranslationContext
strContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
strOptions = ThisApplication.TransientObjects.CreateNameValueMap
strDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If strPDFAddIn.HasSaveCopyAsOptions(strDataMedium, strContext, strOptions) Then
strOptions.Value("All_Color_AS_Black") = 0
strOptions.Value("Remove_Line_Weights") = 0
strOptions.Value("Vector_Resolution") = 400
strOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet
End If
'Set the PDF target file name
strDataMedium.FileName = strFullFileName
'Publish document as PDF
strPDFAddIn.SaveCopyAs(strDocument, strContext, strOptions, strDataMedium)
'----------- export the sheet to dwg -------------------
strFullFileName = strDwgFolder & "\" & strFileNum2 & ".dwg"
' Get the DWG translator Add-In.
strDWGAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
' Check whether the translator has 'SaveCopyAs' options
If strDWGAddIn.HasSaveCopyAsOptions(strDocument, strContext, strOptions) Then
    ' DWG version.
    ' 23 = ACAD 2000
    ' 25 = ACAD 2004
    ' 27 = ACAD 2007
    ' 29 = ACAD 2010
    strOptions.Value("DwgVersion") = 27
	Dim strIniFile As String
	strIniFile = "D:\Local Server\Data\Heaslip Autodesk Customization\Templates\DWGSubmittalConfig.ini"
	' Create the name-value that specifies the ini file to use.
	strOptions.Value("Export_Acad_IniFile") = strIniFile
End If
'Set the DWG target file name
'Publish the active sheet as DWG 2007
strDWGAddIn.SaveCopyAs(strDocument, strContext, strOptions, strDataMedium)
'Delete the titleblock, border, and stamp from the current sheet before continuing to the next sheet
strSheet.TitleBlock.Delete()
strSheet.Border.Delete()
'MessageBox.Show("Sheet " & strCurrentSeqNum & " has successfully been exported", "Sheet Publish Status")
Next
MessageBox.Show("Publishing Completed","")
End Sub
End Sub
 Thanks...
Message 7 of 9
Mike.Wohletz
Ok I see that the property is declared inside an IF statement and then tried to be used outside of that. This is not posible to do insise of an IF or loop so when this is the case you will need to set something of a declared variable or public property decalared outside of this to make it available through the process. I have included that I think will work for you below.
    Public Sub Main()
        Dim SymbolName As String = Nothing ' we are going to declare this and set it to nothing early in the game and use it later
        question = MessageBox.Show("Ready to commence publishing?", "Confirm Publish", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
            Return
        Else
        End If
        If Dir(strPdfFolder, vbDirectory) = "" Then MkDir(strPdfFolder)
        If Dir(strDwgFolder, vbDirectory) = "" Then MkDir(strDwgFolder)
            Next
                    SymbolName = symbolDef.Name
                End If
            Next
        Else
        End If
            strSheet.activate()
            strCurrentSeqNum = SheetName.substring(0, ColonIndex)
            '<snipped for length>
            If strStampRequired = True And Not SymbolName Is Nothing Then ' we will make sure it is wanted and also check that the property declared
                ' at the top of this sub was set to something so we dont pass an empty string
                InsertSymbol(SymbolName)
            Else
            End If
            End If
                ' DWG version.
                ' 23 = ACAD 2000
                ' 25 = ACAD 2004
                ' 27 = ACAD 2007
                ' 29 = ACAD 2010
            End If
        Next
        MessageBox.Show("Publishing Completed", "")
End Sub
    End Sub
Message 8 of 9
Hi Mike, that worked great.  Thank you very much for all the help!
Message 9 of 9
ilya.galaktionov
Could you help me. How to create ilogic rule for One Sketched Symbol without messege:
