[iLogic] copy external file from A to B and delete original file
amarcoc
amarcoc
Hi.
I need to do a simple task using iLogic
I want to move a file from:
"C:\TEMP\OUTPUT"
to:
ThisDoc.Path & "\PDF Automaticos\"
or maybe copy file and delete original.
How can this be done? I have searched but didn't find the solution.
clutsa
Should be as simple as...
Dim source As String = "C:\TEMP\OUTPUT\TargetDocument.txt" 'change as needed
Dim destination As String = ThisDoc.Path & "\MyNewName.txt" 'change as needed
Dim fso = ThisApplication.FileManager.FileSystemObject
fso.copyFile(source, destination, True) 'True to overwrite
fso.DeleteFile(source)
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
