Empty part number if BOM is phantom
mrawesomelemons
mrawesomelemons
I want to empty my part number if my assembly or part BOM structure is set to phantom. I have already fiddled with it a little and came up with some different ideas. Sadly none of them worked how I wanted them to.
What I have now is this:
'Define the open document
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
'Check if the BOM of the document is Phantom
If oDoc.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
	'Set the Part Number to blank
	iProperties.Value("Project", "Part Number") = ""
But if I run it on an assembly I get the error:
The public member BOMStructure for type AssemblyDocument not found.
If I run it on a part I get the error:
The public member BOMStructure for type PartDocument not found.
I don't know if it's possible to have one iRule for both assemblies and parts.
If possible I also would like to run the rule for all the sub assemblies and parts in an assembly if possible.
Can someone help me with this?
clutsa
BOMStructure is part of the ComponentDefinition not the document so this should solve your first issue.
If oDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
clutsa
Try this for the assembly loop...
Dim compDef As ComponentDefinition
compDef = oDoc.ComponentDefinition
Dim compOcc As ComponentOccurrence
For Each compOcc In compDef.Occurrences
	If compOcc.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
	iProperties.Value(compOcc.Name,"Project", "Part Number") = ""
Next
I didn't filly test this so let me know if you have issues.
mrawesomelemons
Thank you for your reply! It seems that I was somewhat close.
It seems to work now for assemblies (phantom parts and assemblies do get their partnumber deleted albeit after a few tries).
But if I run the rule the top assembly doesn't get it's part number deleted. The same goes if I run the rule on a phantom part (ipt).
It seems that we're close. Thank you for your help. If you have some advice please let me know.
Seems like  I got it. I just combined your two replies and it works now.
This is what I ended up with:
Next
mrawesomelemons
Okay my colleague told me this was a good start but he also wants to use it for the parts in a weldment.
We have different categories in the Vault for these. I added them to their templates so I could use them.
I made this iRule to empty the part number. It works but not for any sub assemblies or parts in an assembly.
What am I doing wrong?
'Define all the documents in an assembly
Dim compDef As ComponentDefinition = oDoc.ComponentDefinition
Try
	'Check if the Category is either Without Item or Weldment Part
	If iProperties.Value("CUSTOM", "ItemCategory") = "Without Item" Or iProperties.Value("CUSTOM", "ItemCategory") = "Weldment Part"
Catch
End Try
	Try
		'Check if the Category is either Without Item or Weldment Part for each document in assembly
	Catch
	End Try
Next
'Update file
iLogicVb.UpdateWhenDone = True
EDIT: Got it!
I forgot to add comOcc.Name in front of the iProperty value.
Now it is working great.
For anyone who wants to add this to their Inventor here is the code:
Note:
- This will empty the part number for parts and assemblies with the category "Without Item" or "Weldment Part" in the Vault. These need to be added to the template of those parts.
- If the file doesn't have the property this rule will just skip it.
Try
Catch
End Try
	Try
		If iProperties.Value(compOcc.Name,"CUSTOM", "ItemCategory") = "Without Item" Or iProperties.Value(compOcc.Name,"CUSTOM", "ItemCategory") = "Weldment Part"
	Catch
	End Try
Next
'Update file
mrawesomelemons
After using it today I did find a bug. I managed to fix it and now it works.
This is the code I am using:
Try
Catch
End Try
If oDoc.DocumentType = kAssemblyDocumentObject
	Try
	Catch
	End Try
Next
'Update file
