iLogic Copy Blocks part to part
dusan.naus.trz
Advisor Advisor
dusan.naus.trz
I searched for this function in Inventor, I did not find any import of blocks from files. I didn't find anything on the forum either.
Question: Is it possible using ilogic?
1. I need to copy 1 block named ROWS_poz_01 from RoWS.ipt file to Shaft ipt file
2. I need to copy all the blocks from the RoWS.ipt file to the Shaft ipt file
JhoelForshav
Hi @dusan.naus.trz
I wrote this simple CopyBlocks sub for you.
First argument is the document to copy the blocks from.
Second argument is the document to copy the blocks to.
Third argument is the name of the block you want to copy. If you don't enter anything here all blocks will be copied.
See example below 🙂
Sub Main
	'Document to copy from
	Dim oDoc As PartDocument = ThisApplication.Documents.Open("C:\Temp\CopyBlocks\ROWS.ipt", False)
	'Call sub - if you add a name as third argument then only that block will be copied, otherwise every block will be copied
	CopyBlocks(oDoc, ThisDoc.Document, "ROWS_poz_01")
End Sub
Sub CopyBlocks(fromDoc As Document, toDoc As Document, Optional oName As String = "")
	If oName <> ""
		fromDoc.ComponentDefinition.SketchBlockDefinitions.Item(oName).CopyTo(toDoc)
	Else
		For Each oBlock As SketchBlockDefinition In fromDoc.ComponentDefinition.SketchBlockDefinitions
			oBlock.CopyTo(toDoc)
		Next
End Sub
dusan.naus.trz
Hello, thank you very much. It works great.
dimamazutaMMJ32
Hello. Is there a way to copy a sketch from different part to opened file?
