Ilogic: Add all weldment parts automatically to drawing?
Ivil
Message 1 of 8
Ivil
Hi!
We use multiple details to one drawing, and we are using are placing our parts from Model state>Weldment preparation. This works out well for us , and all parts get a uniqe item number. What i´m looking for is if someone has made a ilogic script to add the first view of all parts automatically. This should make our drawing generation much quicker.
It´s not important to have views tidy, just that all parts are generated. Thanks /Andreas
Replies (7)
Message 2 of 8
dutt.thakar
@Ivil
Are you looking for something like this?
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim doc As AssemblyDocument = ThisDrawing.ModelDocument
'doc = ThisDrawing.ModelDocument
Dim i As Integer = 0
Dim oOcc As ComponentOccurrence
For Each oOcc In doc.ComponentDefinition.Occurrences
	If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject
		MessageBox.Show(oOcc.Name)
		Dim oPT2d As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(i,i) ' to change the placement with coordinates
		Dim oView As DrawingView = oSheet.DrawingViews.AddBaseView(doc,oPT2d,1,ViewOrientationTypeEnum.kFrontViewOrientation,DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
		oView.SetWeldmentState(WeldmentStateEnum.kPreparationsWeldmentState, oOcc)
		i = i+1
Next
 You need to adjust the scale (1 in Bold, which you can change) and placement as per your requirement.
Hope this will be helpful.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Message 3 of 8
SevInventor
Thanks, this helps me a lot. Is it possible to add each component only once if there are many Occurrences of the same part?
Message 4 of 8
Ivil
Wow! So great! Thank you so much!
Message 5 of 8
dutt.thakar
@Ivil
Can you accept the answer as a solution? , so that other users know that it is solved and helpful for everyone in the future.
Dutt Thakar
LinkedIn
Message 6 of 8
Ivil
I agree with severin.hainbuchner that it would be great to have it only put out one instace of a part to the drawing. Would be super helpful.
I don´t know if you are a deveoper for Autodesk or a regular user?
Other things to wish for:
-Auto ballon woud be great
-Put views outside the drawing (not stacked would be preferd)
You have solved one of the limitations of "Inventors one part per drawing mindset". I hope that this can evolve and make inventor even better for several parts per drawing! Thank you!
Message 7 of 8
dutt.thakar
@Ivil and @SevInventor
A quick and dirty solution I would say, to not get the multiple views for the same part, but is only applicable if you are not changing the browser node names, as soon as you change browser node names, this will not work, (that is why I am stating a quick and dirty solution)
See below code.
	If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject And oOcc.Name.Contains(":1") Then
		Dim oView As DrawingView = oSheet.DrawingViews.AddBaseView(doc, oPT2d, 1, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
		i = i+1
Next
Dutt Thakar
LinkedIn
Message 8 of 8
A.Acheson
@Ivil
The auto balloon and auto dimension are a very involved process. They require each face or edge that needs an annotation to be named in the model space. Then each named face needs to be loaded into the code. If the parts get turned off you need to code that scenario in to, too hide the dimension. I am sure practices makes perfect. There is examples on this forum and from API help.
Regarding the view placement if you target this area shown below. You can position the views where you like, the same principle applies for parts list, revision boxes, tables, symbols etc. The position can also set after placement.
You will find examples on this forum.
Regards
Alan
