- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello.
I work on customer STEP-Files very often. So I have created an iLogic-rule that closes an hole "face" with an extrusion and places a threaded hole at the same position.
That works mostly well exept when the EoP-Marker ist moved, so that some already placed features are suppressed. So when it comes to the second "pick" for the circular entitie, nothing is selectable or is highlighted for selection.
Maybe someone knows, wheres the bug in my code.
Thanks for your help 🙂.
'Definition Dim oDoc As PartDocument = ThisApplication.ActiveDocument Dim oApp As Inventor.Application = ThisApplication Dim Bohrungstiefe As Double Dim Gewindetiefe As Double Dim Steigung As Double Dim Nennmass As String 'Definition der transienten Geometrie Dim oTransGeom As TransientGeometry oTransGeom = ThisApplication.TransientGeometry 'referenzieren der Komponenten Definition Dim oCompDef As PartComponentDefinition oCompDef = oDoc.ComponentDefinition 'nachdem Regel abgearbeitet ist, startet sie wieder von vorn TheStart : On Error GoTo ENDE 'Skizzenebene wählen Dim oFace As Object = Nothing oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Startfläche wählen") 'Skizze erstellen Dim oSketch As PlanarSketch = Nothing oSketch = oCompDef.Sketches.Add(oFace) oSketch.Edit 'zu ersetzende Bohrung wählen Dim oObject As Object = Nothing oObject = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllCircularEntities, "Bohrungskante wählen") Hole_Dia = oObject.geometry.radius*2*10 'Converted to Diameter and mm 'Endfläche der Bohrung wählen, entspricht auch der neuen Bohrungstiefe Dim Endflaeche As Object = Nothing Endflaeche = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Endfläche wählen") Bohrungstiefe = (ThisApplication.MeasureTools.GetMinimumDistance(oFace, Endflaeche))*10 'Bohrungskante in Skizze projezieren Call oSketch.AddByProjectingEntity(oObject) oSketch.ExitEdit 'Profil für die Extrusion wählen Dim oProfile As Profile = Nothing oProfile = oSketch.Profiles.AddForSolid 'Bohrung verschließen mit einer Extrusion bis zu angewählten Endfläche Dim oExtrudeDef As ExtrudeDefinition oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation) Call oExtrudeDef.SetToExtent(Endflaeche, kNegativeExtentDirection) Dim oExtrude As ExtrudeFeature oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef) 'Skizzenpunkt in der erstellten Skizze als Zentrum der neuen Bohrung definieren oSketch.Edit oHoleCenter1 = ThisApplication.TransientObjects.CreateObjectCollection oHoleCenter1.Add(oSketch.SketchPoints.Item(1)) oSketch.ExitEdit 'Skizze wird verwendet von der Extrusion und der neuen Bohrung oSketch.Shared = True 'Anhand vom ursprünglichen Bohrungsdurchmesser ein Nennmaß für das Gewinde wählen Select Case Hole_Dia Case <= 1.57 Nennmass = "M2x0.4" Steigung = 0.4 Case <= 2.01 Nennmass = "M2.5x0.45" Steigung = 0.45 Case <= 2.46 Nennmass = "M3x0.5" Steigung = 0.5 Case <= 3.24 Nennmass = "M4x0.7" Steigung = 0.7 Case <= 4.13 Nennmass = "M5x0.8" Steigung = 0.8 Case <= 4.92 Nennmass = "M6x1" Steigung = 1 Case <= 6.65 Nennmass = "M8x1.25" Steigung = 1.25 Case <= 8.38 Nennmass = "M10x1.5" Steigung = 1.5 Case <= 10.11 Nennmass = "M12x1.75" Steigung = 1.75 Case <= 13.84 Nennmass = "M16x2" Steigung = 2 Case <= 17.29 Nennmass = "M20x2.5" Steigung = 2.5 Case <= 20.75 Nennmass = "M24x3" Steigung = 3 Case <= 26.21 Nennmass = "M30x3.5" Steigung = 3.5 Case <= 31.67 Nennmass = "M36x4" Steigung = 4 Case <= 37.13 Nennmass = "M42x4.5" Steigung = 4.5 Case <= 42.59 Nennmass = "M48x5" Steigung = 5 Case <= 50.05 Nennmass = "M56x5.5" Steigung = 5.5 Case Else Nennmass = "M64x6" Steigung = 6 End Select 'Gewindetiefe festlegen Gewindetiefe = Bohrungstiefe - 3 * Steigung 'Gewindebohrung erstellen Dim oHoleTapInfo As HoleTapInfo oHoleTapInfo = ThisApplication.ActiveDocument.ComponentDefinition.Features.HoleFeatures.CreateTapInfo(True, "ISO Metrisches Profil", Nennmass, "6H", False, Gewindetiefe/10) BottomTipAngle = 140*PI/180 oBohrung2 = ThisApplication.ActiveDocument.ComponentDefinition.Features.HoleFeatures.AddDrilledByDistanceExtent(oHoleCenter1, oHoleTapInfo, Bohrungstiefe/10, PartFeatureExtentDirectionEnum.kPositiveExtentDirection, False, BottomTipAngle) 'Sichtbarkeit der Skizze deaktivieren oSketch.Visible = False 'Wenn erfolgreich, dann beginne wieder am Start mit der nächsten Bohrung GoTo TheStart: Return ENDE:
