iLogic code to turn sketch block visibility on and off
PaulMunford
Autodesk Autodesk
PaulMunford
Hey chaps.
I'va managed to cobble this code together to turn some sketch visibilities on and off. However, what I'd really like to do is have a single sketch containg some blocks, and turn the visibility of the blocks on and off...
I'm struggling to work out how to call the blocks - can YOU help!
Paul
'Iterate through the sketches collection
'Turn the edging indicators On And Off
For Each oSketch In oDoc.ComponentDefinition.Sketches
Select Case  oSketch.Name
	Case "Front Edged"
	If E01 = True Then
	oSketch.Visible = True
	Else oSketch.Visible = False
	End If
	Case "Top Edged"
	If E02 = True Then
	End If
	Case "Back Edged"
	If E03 = True Then
	End If
	Case "Base Edged"
	If E04 = True Then
	End If
End Select
Next
Paul Munford
Technical Onboarding Architect
Linkedin
Curtis_W
Hi Paul,
Here's a quick example:
Dim oSketches As PlanarSketches
oSketches = ThisApplication.ActiveDocument.ComponentDefinition.Sketches
Dim oSketch As PlanarSketch
oSketch = oSketches.Item("Sketch2")
Dim MyArrayList As New ArrayList
MyArrayList.add("Back Edged")
MyArrayList.add("Base Edged")
MyArrayList.add("Front Edged")
MyArrayList.add("Top Edged")
MyArrayList.add("Turn ON all blocks")
MyArrayList.add("Turn OFF all blocks")
myBlock = InputListBox("Select a block to turn ON", _
MyArrayList, MyArrayList.item(0),"iLogic", "Sketch Block Names")
Dim oSketchBlock As SketchBlock
For Each oSketchBlock  In oSketch.SketchBlocks
    'get position of colon, example: MyBlock:2 returns 8
    iPos = InStr(oSketchBlock.Name, ":")
    'get block name, example: MyBlock:2 returns MyBlock
    sBlockName = Left(oSketchBlock.Name, iPos -1)
    If myBlock = "Turn ON all blocks" Then
    oSketchBlock.Visible = True
    Else If myBlock = "Turn OFF all blocks" Then
    oSketchBlock.Visible = False
    Else If myBlock = sBlockName Then
    End If
    'if any sketch block is visible make the sketch visible
    If oSketchBlock.Visible = true Then oSketch.Visible = True
Next
 I hope this helps,
Curtis
PaulMunford
Yay!
Great stuff Curtis. Thanks for your help 🙂
Paul Munford
Linkedin
RoyWickrama_RWEI
Hi Curtis;
Thanks for the posting.
I am using a test version of the coding to make vsible the blocks in my sketch (Sketch12) visible. There are a few blocks. However, while the Sketch12 is not visible, the blocks in the sketch don't turn on (not visible). Could you help me, please.
oSketch = oSketches.Item("Sketch12")
    sBlockName = Left(oSketchBlock.Name, iPos-1)
'    If oSketchBlock.Visible = True Then oSketch.Visible = True
Next
Thanks.
