iLogic Code to Save File
Hey all,
I'm trying to save a file as "PartNumber-SequenceNumber.ipt" with iLogic code. For example, 12345678-0001.ipt is how a file would look if the code were functioning properly.
So far, what I've got is this:
Dim PartNumber As String
Dim SequenceNumber As String
PartNumber = iProperties.Value("Project", "Part Number")
SequenceNumber = iProperties.Value("Custom", "Sequence Number")
ThisDoc.Document.SaveAs(PartNumber & "-" & SequenceNumber, False)
I think I'll need to specify file location too...not sure though.
Thanks in advance!
  -Luke
sigurdurie
Hi I got this from somewhere:
Dim oDocu As Document
oDocu = ThisApplication.ActiveDocument
' Save all "dirty" files
Call oDocu.Save2(True)
Hope it helps
sigurdurie
From what I got from that second link, I updated my code to this:
NewFileName = PartNumber & "-" & SequenceNumber
ThisDoc.Document.SaveAs(Newfilename,False)
The major change here is that I create the NewFileName string before I try to name my file.
It didn't work. Thanks for the idea though.
sigurdurie
But aren't you missing one thing:
NewFileName = PartNumber & "-" & SequenceNumber & ".ipt"
if you are saving to ipt that is
Curtis_Waguespack
