Thank you for the response, Curtis. Additional information is in order...
I typically use the Unwrap tool to generate a dxf from a sheet metal part that cannot be unfolded, and requires additional fabrication. Not my preferred workflow, but these projects do come my way from time to time. Although the resulting dxf is an approximation, at best, the fabricator has been able to use it to create an acceptable part.
Currently, I can generate the dxf using my version or yours, in one of 2 ways:
- RMB on the Unwrap feature
- Manually run the rule
However, my preferred workflow is to set the rule to fire before save, as I do when generating a dxf from a sheet metal part that can be flattened. That worked in 2023, but does not work for this rule in 2024, at least, not on my system. So far all the other rules run fine.
I tested this on your part, and the dxf did not generate:
I only tested this on a few events, but the result is the same.
Can you generate the dxf on your system using Triggers?
Thank you.
