ilogic code to export dxf from Unwrap
b.mccarthy
Message 1 of 10
b.mccarthy
Hello.
There are many routines available to auto-generate a dxf from a flat pattern. Can the same be done for an Unwrap feature?
TIA
Accepted solutions (3)
Replies (9)
Message 2 of 10
Ralf_Krieg
Hello
Assuming:
- the Unwrap feature exist in the part file
- there is just one Unwrap feature
- the feature faces are merged to one face
    Dim oPartDoc As PartDocument=ThisDoc.Document
    Dim oUnwrap As UnwrapFeature = oPartDoc.ComponentDefinition.Features.UnwrapFeatures(1)
    Dim oFace As Object= oUnwrap.SurfaceBody.Faces(1)
    Dim oSelect As SelectSet= oPartDoc.SelectSet
    Dim sFilename As String = System.IO.Path.GetFileNameWithoutExtension(oPartDoc.FullFileName)
	Dim sPath As String = System.IO.Path.GetDirectoryName(oPartDoc.FullFileName)
	Call oSelect.Select(oUnwrap.SurfaceBody.Faces(1))
    If oSelect.Count > 0 Then
        Call ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, sPath & "\" & sFilename & ".dxf")
        Call ThisApplication.CommandManager.ControlDefinitions.Item("GeomToDXFCommand").Execute
    End If
    oSelect.Clear
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 3 of 10
b.mccarthy
Perfect. Thank you!
Message 4 of 10
b.mccarthy
Hello.
I recently upgraded to 2024, and this rule no longer generates a dxf. Any idea why?
Message 5 of 10
Curtis_Waguespack
Hi @b.mccarthy ,
I'm not sure what the issue you're seeing is, but I just ran a simple test part with Inventor 2024 ( build 153) and it worked as expected ( created the DXF of the unwrap surface).
Maybe it's something specific to your geometry?
See attached file for you to test/verify my results if you'd like.
I hope this helps.
Curtis
Message 6 of 10
b.mccarthy
Thank you for the response, Curtis. Additional information is in order...
I typically use the Unwrap tool to generate a dxf from a sheet metal part that cannot be unfolded, and requires additional fabrication. Not my preferred workflow, but these projects do come my way from time to time. Although the resulting dxf is an approximation, at best, the fabricator has been able to use it to create an acceptable part.
Currently, I can generate the dxf using my version or yours, in one of 2 ways:
  • RMB on the Unwrap feature
  • Manually run the rule
However, my preferred workflow is to set the rule to fire before save, as I do when generating a dxf from a sheet metal part that can be flattened. That worked in 2023, but does not work for this rule in 2024, at least, not on my system. So far all the other rules run fine.
I tested this on your part, and the dxf did not generate:
I only tested this on a few events, but the result is the same.
Can you generate the dxf on your system using Triggers?
Thank you.
Message 7 of 10
Curtis_Waguespack
HI @b.mccarthy
I see the same results as you when trying this on the Before Save event
I was able to verify that on the save event the rule is running, and that the surface is getting selected.
I suspect the "PostPriavateEvent" line is the issue, but I'm not sure what would have changed from 2023 to 2024 in this regard, or what the fix is.
Message 8 of 10
Curtis_Waguespack
Oh, wait try this:
Call ThisApplication.CommandManager.ControlDefinitions.Item("GeomToDXFCommand").Execute2(True)
Message 9 of 10
b.mccarthy
Success!!
What does this tell Inventor to do?
Message 10 of 10
Curtis_Waguespack
It's about when the command is told to run ( before or after the message).  see link
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-1715970A-16DF-43E9-9C6D-2ED3336C5420
In this case because there isn't really a message because the DXF command is using the file name off the Inventor clipboard, rather than displaying an input message box/form, but somehow it makes a difference to 2024.
Autodesk likely fixed something that was broke, or broke something that was fixed in the way that this was working ????
