ilogic code to delete unused sketches in parts
BasVanVelsen5347
BasVanVelsen5347
I have attached an assembly consisting out of parts and a subassembly.
All the parts that are used have an unused sketch that I want to delete.
Preferably I want to run an ilogic code from the toplevel assembly.
I managed to create this ilogic code from some examples in this forum that works when started on a part level.
Hope you can help.
Bas
Sub Main()
    Dim oDoc As Document = ThisApplication.ActiveDocument
    Dim oCD As ComponentDefinition= oDoc.ComponentDefinition
    Dim oSketch As PlanarSketch
    For Each oSketch In oCD.Sketches
        oSketch.Delete
    Next
End Sub
WCrihfield
Hi @BasVanVelsen5347.  You can try this iLogic code if you want.
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
	Exit Sub
End If
Dim oADoc As AssemblyDocument = ThisDoc.Document
Dim oRefDocs As DocumentsEnumerator = oADoc.AllReferencedDocuments
For Each oRefDoc As Document In oRefDocs
	If Not oRefDoc.IsModifiable Then Continue For
	Dim oSketches As PlanarSketches = oRefDoc.ComponentDefinition.Sketches
	For Each oSketch As PlanarSketch In oSketches
		If oSketch.Consumed = False Then
			Try
				oSketch.Delete
			Catch
				MsgBox("Could not delete sketch named " & oSketch.Name & vbCrLf & _
				"within the following document" & vbCrLf & oRefDoc.FullDocumentName,,"")
			End Try
		End If
	Next 'oSketch
Next 'oRefDoc
oADoc.Update
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
BasVanVelsen5347
Hi WCrihfield, your code is working perfect.
Thanks for the quick reply.
Bas
