ilogic code runs fine unless part is rotated
They_Call_Me_Jake
They_Call_Me_Jake
I have created some code to create a hole pattern and create a separate sketch afterwards. My code runs fine in an assembly unless the part I am trying to put the hole pattern in has been rotated or a face on the part has been rotated using the Direct Edit however it runs fine if I run the rule in the part itself. It doesn't just cause the rule to crash but it causes Inventor itself to crash.  If anyone can explain what might be causing the problem it would be very appreciated. Here is the code for the hole pattern rule I made. It seems to be crashing at the point where it is trying to dimesion a line that is drawn in by the code but only when I run the rule in an assembly .
Option explicit on
Class ThisRule
Dim RepeatRule As Boolean
Dim oAsmDoc As AssemblyDocument
Dim oAsmCompDef As AssemblyComponentDefinition
Dim oPartDoc As PartDocument
Dim oPartCompDef As PartComponentDefinition
Dim oCompOcc As ComponentOccurrence
Dim oPart As ComponentOccurrence
Dim oFace As Face
Dim oFrontEdge As Edge
Dim oLeftEdge As Edge
Dim oRightEdge As Edge
Dim oTG As TransientGeometry
Dim oSelCompName As String
End Class
Sub Main()
'	RepeatRule = True
'	While RepeatRule = True
		CreateHoles()
'	End While
End Sub
Sub CreateHoles()
	'Main Declarations
	 oTG = ThisApplication.TransientGeometry
	'Check Document Type
	Dim oDocType As Document = ThisDoc.Document
	Dim DocumentType As Integer
	If oDocType.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		DocumentType = 1
	Else If oDocType.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		DocumentType = 2
	Else If oDocType.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
		MessageBox.Show("This rule can only be run in an" _
		& vbLf & "Assembly or Part Document. Please" _
		& vbLf & "open the correct document type and" _
		& vbLf & "run the rule again", "iLogic")
		Exit Sub
	Dim oSelFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select Face")
	If oSelFace Is Nothing Then
		RepeatRule = False
		Exit Sub
	If DocumentType = 1 Then
		oAsmDoc = ThisDoc.Document
		oAsmCompDef = oAsmDoc.ComponentDefinition
		oCompOcc = oSelFace.Parent.Parent
		oPartCompDef = oCompOcc.Definition
		oSelCompName = oCompOcc.Name
		oFace = oSelFace.NativeObject
		For Each oCompOcc In oAsmCompDef.Occurrences
			If oCompOcc.DefinitionDocumentType <> kPartDocumentObject Then
				MessageBox.Show("This rule cannot be run in an assembly with" _
				& vbLf & "sub-assemblies. Please open the sub-assembly" _
				& vbLf & "in a new window and run the rule again", "iLogic")
				Exit Sub
		Next
			Dim oOccName As String = oCompOcc.Name
			If Not oCompOcc.Name = oSelCompName Then
				oCompOcc.Enabled = False
		Next
	Else If DocumentType = 2 Then
		oPartDoc = ThisDoc.Document
		oPartCompDef = oPartDoc.ComponentDefinition
		oFace = oSelFace
	Dim oSelFrontEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeLinearFilter, "Select Front Edge")
	If oSelFrontEdge Is Nothing Then
					oCompOcc.Enabled = True
			Next
		RepeatRule = False
		Exit Sub
	Dim oSelLeftEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllLinearEntities, "Select Left Edge")
	If oSelLeftEdge Is Nothing Then
			Next
		RepeatRule = False
		Exit Sub
	Dim oSelRightEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllLinearEntities, "Select Right Edge")
	If oSelRightEdge Is Nothing Then
			Next
		RepeatRule = False
		Exit Sub
		oFrontEdge = oSelFrontEdge.NativeObject
		oLeftEdge = oSelLeftEdge.NativeObject
		oRightEdge = oSelRightEdge.NativeObject
	'Create Sketch and Set Origin and Direction
	Dim oSketch1 As PlanarSketch = oPartCompDef.Sketches.Add(oFace, False)
	oSketch1.OriginPoint = oFrontEdge.StartVertex
	oSketch1.AxisEntity = oFrontEdge
	oSketch1.AxisIsX = True
	oSketch1.NaturalAxisDirection = True
	'Project Edges into Sketch
	Dim oFrontLine As SketchLine = oSketch1.AddByProjectingEntity(oFrontEdge)
	Dim oLeftLine As SketchLine = oSketch1.AddByProjectingEntity(oLeftEdge)
	Dim oRightLine As SketchLine = oSketch1.AddByProjectingEntity(oRightEdge)
	Dim oMaterial As String = Parameter.Param("MaterialType").Value
	Dim oHoleType As String = Parameter.Param("HoleType").Value
	Dim oHoleSize As String = Parameter.Param("HoleLayers").Value
	'Add Sketch and set sketch origin point to the startVertex of the FrontEdge
	'Project a SketchLine and check direction in X to see if the coordinate system needs
	'To be flipped so the circles fall inside the parent part.
	Dim oLeftDist As Double = ThisApplication.MeasureTools.GetMinimumDistance(oFrontLine.StartSketchPoint, oLeftLine)
	Dim oRightDist As Double = ThisApplication.MeasureTools.GetMinimumDistance(oFrontLine.StartSketchPoint, oRightLine)
	If oLeftDist > oRightDist Then
			oSketch1.OriginPoint = oFrontEdge.StopVertex
		If oFrontLine.Geometry.Direction.X > 0 Then
			oSketch1.NaturalAxisDirection = False
	Else If oLeftDist < oRightDist Then
		If oFrontLine.Geometry.Direction.X < 0 Then
'	'Create the name for the sketch based on user assigned parameters
	Dim oSketchNameSuffix As Integer
	Dim oNameType As String
	Dim oSketchName As String
	Dim oNameCompare As String
	Dim oNameNumCount As Integer
	Dim oNameCharCount As Integer
	If oHoleType = "Thru" Then
		oSketchNameSuffix = 0
		oNameType = "_Hole_"
		oNameCompare = "SK" & oNameType
		oNameCharCount = 8
		oNameNumCount = 9
	Else If oHoleType = "Pilot" Then
		oNameType = "_Pilot_"
		oNameCharCount = 9
		oNameNumCount = 10
'	'Check all sketches in the model tree and compare the names to the
'	'name of the newly created sketch and if name exists increment the
'	'suffix by 1. Continue until the newly created sketch name is unique
'	'and can be used.
	For Each oSketchNameCheck As Sketch In oPartCompDef.Sketches
		If Left(oSketchNameCheck.Name,oNameCharCount) = oNameCompare Then
			Dim oSketchNumber As Integer = Val(Mid(oSketchNameCheck.Name, oNameNumCount, 2))
	        While oSketchNameSuffix <= oSketchNumber
				oSketchNameSuffix = oSketchNameSuffix + 1
			End While
	Next
	Dim oLayer As String = Parameter.Param("HoleLayers").Value
	oSketchName = oNameCompare & oSketchNameSuffix
	Dim oHoleName As String = "HL" & oNameType & oSketchNameSuffix
	Dim oPatternName As String = "PT" & oNameType & oSketchNameSuffix
	Dim oSketchLayerName As String = "SK_" & oSketchNameSuffix & "_" & oLayer
	oSketch1.Name = oSketchName
'	'QTY of holes and distance from front, left and right edges
	Dim oFrontEdgeDistance As Double = ThisApplication.MeasureTools.GetMinimumDistance(oFrontEdge.StartVertex, oFrontEdge.StopVertex)
	Dim oFromLeftEdge As Double = Parameter.Param("FromLeftEdge").Value
	Dim oFromRightEdge As Double = oFrontEdgeDistance - (Parameter.Param("FromRightEdge").Value)
	Dim oFromFrontEdge As Double = Parameter.Param("FromFrontEdge").Value
	Dim oLine As SketchLine = oSketch1.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(oFromLeftEdge, oFromFrontEdge), oTG.CreatePoint2d(oFromRightEdge, oFromFrontEdge))
	Dim oLineLength As Double = oLine.Length
	Dim oQty As Integer = Floor(oLineLength / (Parameter.Param("DesiredHoleSeperation").Value)) + 1
	Dim oActualHoleSep As Double = (oLineLength / (oQty - 1)) / 2.54
	Parameter("ActualHoleSeperation") = oActualHoleSep
	Parameter("LineLength") = oLineLength / 2.54
	Parameter.UpdateAfterChange = True
	Parameter("HoleQty") = oQty
'	'Dimension the FitToPath Line
	Dim oConstraint As DimensionConstraint
	Dim TextPoint As Point2d
	TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(oFromLeftEdge - 1, oFromFrontEdge + 1)
	oConstraint = oSketch1.DimensionConstraints.AddTwoPointDistance(oLine.StartSketchPoint, oFrontLine.StartSketchPoint, DimensionOrientationEnum.kVerticalDim, TextPoint, False)
	TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(oFromLeftEdge -1, oFromFrontEdge + 2)
	oConstraint = oSketch1.DimensionConstraints.AddTwoPointDistance(oLine.StartSketchPoint, oLeftLine.EndSketchPoint, DimensionOrientationEnum.kHorizontalDim, TextPoint, False)
	TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(oFromRightEdge + 1, oFromFrontEdge + 1)
	oConstraint = oSketch1.DimensionConstraints.AddTwoPointDistance(oLine.EndSketchPoint, oFrontLine.EndSketchPoint, DimensionOrientationEnum.kVerticalDim, TextPoint, False)
	TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(oFromRightEdge + 1, oFromFrontEdge + 2)
	oConstraint = oSketch1.DimensionConstraints.AddTwoPointDistance(oLine.EndSketchPoint, oRightLine.StartSketchPoint, DimensionOrientationEnum.kHorizontalDim, TextPoint, False)
	TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(oFromLeftEdge + oLine.Length/2, oFromFrontEdge + 2)
	oConstraint = oSketch1.DimensionConstraints.AddTwoPointDistance(oLine.StartSketchPoint, oLine.EndSketchPoint, DimensionOrientationEnum.kHorizontalDim, TextPoint, True)
	Dim oLineLengthParam As String = oConstraint.Parameter.Name
	Dim oHoleCenters As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	oHoleCenters.Add(oLine.StartSketchPoint)
	Dim oPoint As Point = oSketch1.SketchToModelSpace(oTG.CreatePoint2d(oFromLeftEdge, oFromFrontEdge))
	Dim oLinearPlacementDef As LinearHolePlacementDefinition = oPartCompDef.Features.HoleFeatures.CreateLinearPlacementDefinition(oFace, oLeftEdge, oFromLeftEdge, oFrontEdge, oFromFrontEdge, oPoint)
	Dim oDrillDia As String
	Dim Separators() As Char = {"."c, "-"c}
	Dim Sentence As String = oLayer
	Dim Words As Array = Sentence.Split(Separators)
	Dim i As Integer = 0
	For Each wrd In Words
		If i = 2 Then
			oDrillDia = "." &(Val(Words(i)))
		i += 1
	Next
	'specify word splitting characters "space" and "dash"
	Dim oHoleFeature As HoleFeature = oPartCompDef.Features.HoleFeatures.AddDrilledByThroughAllExtent(oLinearPlacementDef, oDrillDia, kPositiveExtentDirection)
	oHoleFeature.Name = oHoleName
	' Create the object collection.
	Dim FeatureColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	Dim oHoleFeatureItem As Integer
	' Add the newly created hole feature to the collection.
	For Each oHoleFeature In oPartCompDef.Features.HoleFeatures
		If oHoleFeature.Name = oHoleName Then
			Call FeatureColl.Add(oHoleFeature)
	Next
	Dim oPatternPath As Object = oPartCompDef.Features.CreatePath(oSketch1.SketchLines.Item(4))
	' Create the pattern
	Dim oPatternFeature As RectangularPatternFeature = oPartCompDef.Features.RectangularPatternFeatures.Add(FeatureColl, oPatternPath, True, oQty, _
	20, PatternSpacingTypeEnum.kFitToPathLength, , , , , , , , , kIdentical)
	oPatternFeature.Name = oPatternName
	Dim oSketch2 As PlanarSketch = oPartCompDef.Sketches.Add(oFace, False)
	Dim oHoleFace As Face = oHoleFeature.Faces.Item(1)
	Dim oHoleEdge As Edge = oHoleFace.Edges.Item(1)
	oSketch2.AddByProjectingEntity(oHoleEdge)
	For Each oPatFace As Face In oPatternFeature.Faces
		Dim oPatEdge As Edge = oPatFace.Edges.Item(1)
		oSketch2.AddByProjectingEntity(oPatEdge)
	Next
	oSketch2.Name = oSketchLayerName
	oSketch2.Visible = False
		Next
'	iLogicVb.UpdateWhenDone = True
	InventorVb.DocumentUpdate()
End Sub
They_Call_Me_Jake
I just figured it out. I had some old code in my rule when I was trying different things that would try to create a point in ModelSpace that I could use to redefine the Sketch Origin until I realized that the Sketch Origin can only be "Snapped" to a Vertex
As Soon as I deleted this now unused Code it works.
