- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created some code to create a hole pattern and create a separate sketch afterwards. My code runs fine in an assembly unless the part I am trying to put the hole pattern in has been rotated or a face on the part has been rotated using the Direct Edit however it runs fine if I run the rule in the part itself. It doesn't just cause the rule to crash but it causes Inventor itself to crash. If anyone can explain what might be causing the problem it would be very appreciated. Here is the code for the hole pattern rule I made. It seems to be crashing at the point where it is trying to dimesion a line that is drawn in by the code but only when I run the rule in an assembly .
Option explicit on Class ThisRule Dim RepeatRule As Boolean Dim oAsmDoc As AssemblyDocument Dim oAsmCompDef As AssemblyComponentDefinition Dim oPartDoc As PartDocument Dim oPartCompDef As PartComponentDefinition Dim oCompOcc As ComponentOccurrence Dim oPart As ComponentOccurrence Dim oFace As Face Dim oFrontEdge As Edge Dim oLeftEdge As Edge Dim oRightEdge As Edge Dim oTG As TransientGeometry Dim oSelCompName As String End Class Sub Main() ' RepeatRule = True ' While RepeatRule = True CreateHoles() ' End While End Sub Sub CreateHoles() 'Main Declarations oTG = ThisApplication.TransientGeometry 'Check Document Type Dim oDocType As Document = ThisDoc.Document Dim DocumentType As Integer If oDocType.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then DocumentType = 1 Else If oDocType.DocumentType = DocumentTypeEnum.kPartDocumentObject Then DocumentType = 2 Else If oDocType.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then MessageBox.Show("This rule can only be run in an" _ & vbLf & "Assembly or Part Document. Please" _ & vbLf & "open the correct document type and" _ & vbLf & "run the rule again", "iLogic") Exit Sub End If Dim oSelFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select Face") If oSelFace Is Nothing Then RepeatRule = False Exit Sub End If If DocumentType = 1 Then oAsmDoc = ThisDoc.Document oAsmCompDef = oAsmDoc.ComponentDefinition oCompOcc = oSelFace.Parent.Parent oPartCompDef = oCompOcc.Definition oSelCompName = oCompOcc.Name oFace = oSelFace.NativeObject For Each oCompOcc In oAsmCompDef.Occurrences If oCompOcc.DefinitionDocumentType <> kPartDocumentObject Then MessageBox.Show("This rule cannot be run in an assembly with" _ & vbLf & "sub-assemblies. Please open the sub-assembly" _ & vbLf & "in a new window and run the rule again", "iLogic") Exit Sub End If Next For Each oCompOcc In oAsmCompDef.Occurrences Dim oOccName As String = oCompOcc.Name If Not oCompOcc.Name = oSelCompName Then oCompOcc.Enabled = False End If Next Else If DocumentType = 2 Then oPartDoc = ThisDoc.Document oPartCompDef = oPartDoc.ComponentDefinition oFace = oSelFace End If Dim oSelFrontEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeLinearFilter, "Select Front Edge") If oSelFrontEdge Is Nothing Then If DocumentType = 1 Then For Each oCompOcc In oAsmCompDef.Occurrences Dim oOccName As String = oCompOcc.Name If Not oCompOcc.Name = oSelCompName Then oCompOcc.Enabled = True End If Next End If RepeatRule = False Exit Sub End If Dim oSelLeftEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllLinearEntities, "Select Left Edge") If oSelLeftEdge Is Nothing Then If DocumentType = 1 Then For Each oCompOcc In oAsmCompDef.Occurrences Dim oOccName As String = oCompOcc.Name If Not oCompOcc.Name = oSelCompName Then oCompOcc.Enabled = True End If Next End If RepeatRule = False Exit Sub End If Dim oSelRightEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllLinearEntities, "Select Right Edge") If oSelRightEdge Is Nothing Then If DocumentType = 1 Then For Each oCompOcc In oAsmCompDef.Occurrences Dim oOccName As String = oCompOcc.Name If Not oCompOcc.Name = oSelCompName Then oCompOcc.Enabled = True End If Next End If RepeatRule = False Exit Sub End If If DocumentType = 1 Then oFrontEdge = oSelFrontEdge.NativeObject oLeftEdge = oSelLeftEdge.NativeObject oRightEdge = oSelRightEdge.NativeObject Else If DocumentType = 2 Then oFrontEdge = oSelFrontEdge oLeftEdge = oSelLeftEdge oRightEdge = oSelRightEdge End If 'Create Sketch and Set Origin and Direction Dim oSketch1 As PlanarSketch = oPartCompDef.Sketches.Add(oFace, False) oSketch1.OriginPoint = oFrontEdge.StartVertex oSketch1.AxisEntity = oFrontEdge oSketch1.AxisIsX = True oSketch1.NaturalAxisDirection = True 'Project Edges into Sketch Dim oFrontLine As SketchLine = oSketch1.AddByProjectingEntity(oFrontEdge) Dim oLeftLine As SketchLine = oSketch1.AddByProjectingEntity(oLeftEdge) Dim oRightLine As SketchLine = oSketch1.AddByProjectingEntity(oRightEdge) Dim oMaterial As String = Parameter.Param("MaterialType").Value Dim oHoleType As String = Parameter.Param("HoleType").Value Dim oHoleSize As String = Parameter.Param("HoleLayers").Value 'Add Sketch and set sketch origin point to the startVertex of the FrontEdge 'Project a SketchLine and check direction in X to see if the coordinate system needs 'To be flipped so the circles fall inside the parent part. Dim oLeftDist As Double = ThisApplication.MeasureTools.GetMinimumDistance(oFrontLine.StartSketchPoint, oLeftLine) Dim oRightDist As Double = ThisApplication.MeasureTools.GetMinimumDistance(oFrontLine.StartSketchPoint, oRightLine) If oLeftDist > oRightDist Then oSketch1.OriginPoint = oFrontEdge.StopVertex If oFrontLine.Geometry.Direction.X > 0 Then oSketch1.NaturalAxisDirection = False End If Else If oLeftDist < oRightDist Then oSketch1.OriginPoint = oFrontEdge.StartVertex If oFrontLine.Geometry.Direction.X < 0 Then oSketch1.NaturalAxisDirection = False End If End If ' 'Create the name for the sketch based on user assigned parameters Dim oSketchNameSuffix As Integer Dim oNameType As String Dim oSketchName As String Dim oNameCompare As String Dim oNameNumCount As Integer Dim oNameCharCount As Integer If oHoleType = "Thru" Then oSketchNameSuffix = 0 oNameType = "_Hole_" oNameCompare = "SK" & oNameType oNameCharCount = 8 oNameNumCount = 9 Else If oHoleType = "Pilot" Then oSketchNameSuffix = 0 oNameType = "_Pilot_" oNameCompare = "SK" & oNameType oNameCharCount = 9 oNameNumCount = 10 End If ' 'Check all sketches in the model tree and compare the names to the ' 'name of the newly created sketch and if name exists increment the ' 'suffix by 1. Continue until the newly created sketch name is unique ' 'and can be used. For Each oSketchNameCheck As Sketch In oPartCompDef.Sketches If Left(oSketchNameCheck.Name,oNameCharCount) = oNameCompare Then Dim oSketchNumber As Integer = Val(Mid(oSketchNameCheck.Name, oNameNumCount, 2)) While oSketchNameSuffix <= oSketchNumber oSketchNameSuffix = oSketchNameSuffix + 1 End While End If Next Dim oLayer As String = Parameter.Param("HoleLayers").Value oSketchName = oNameCompare & oSketchNameSuffix Dim oHoleName As String = "HL" & oNameType & oSketchNameSuffix Dim oPatternName As String = "PT" & oNameType & oSketchNameSuffix Dim oSketchLayerName As String = "SK_" & oSketchNameSuffix & "_" & oLayer oSketch1.Name = oSketchName ' 'QTY of holes and distance from front, left and right edges Dim oFrontEdgeDistance As Double = ThisApplication.MeasureTools.GetMinimumDistance(oFrontEdge.StartVertex, oFrontEdge.StopVertex) Dim oFromLeftEdge As Double = Parameter.Param("FromLeftEdge").Value Dim oFromRightEdge As Double = oFrontEdgeDistance - (Parameter.Param("FromRightEdge").Value) Dim oFromFrontEdge As Double = Parameter.Param("FromFrontEdge").Value Dim oLine As SketchLine = oSketch1.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(oFromLeftEdge, oFromFrontEdge), oTG.CreatePoint2d(oFromRightEdge, oFromFrontEdge)) Dim oLineLength As Double = oLine.Length Dim oQty As Integer = Floor(oLineLength / (Parameter.Param("DesiredHoleSeperation").Value)) + 1 Dim oActualHoleSep As Double = (oLineLength / (oQty - 1)) / 2.54 Parameter("ActualHoleSeperation") = oActualHoleSep Parameter("LineLength") = oLineLength / 2.54 Parameter.UpdateAfterChange = True Parameter("HoleQty") = oQty ' 'Dimension the FitToPath Line Dim oConstraint As DimensionConstraint Dim TextPoint As Point2d TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(oFromLeftEdge - 1, oFromFrontEdge + 1) oConstraint = oSketch1.DimensionConstraints.AddTwoPointDistance(oLine.StartSketchPoint, oFrontLine.StartSketchPoint, DimensionOrientationEnum.kVerticalDim, TextPoint, False) TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(oFromLeftEdge -1, oFromFrontEdge + 2) oConstraint = oSketch1.DimensionConstraints.AddTwoPointDistance(oLine.StartSketchPoint, oLeftLine.EndSketchPoint, DimensionOrientationEnum.kHorizontalDim, TextPoint, False) TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(oFromRightEdge + 1, oFromFrontEdge + 1) oConstraint = oSketch1.DimensionConstraints.AddTwoPointDistance(oLine.EndSketchPoint, oFrontLine.EndSketchPoint, DimensionOrientationEnum.kVerticalDim, TextPoint, False) TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(oFromRightEdge + 1, oFromFrontEdge + 2) oConstraint = oSketch1.DimensionConstraints.AddTwoPointDistance(oLine.EndSketchPoint, oRightLine.StartSketchPoint, DimensionOrientationEnum.kHorizontalDim, TextPoint, False) TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(oFromLeftEdge + oLine.Length/2, oFromFrontEdge + 2) oConstraint = oSketch1.DimensionConstraints.AddTwoPointDistance(oLine.StartSketchPoint, oLine.EndSketchPoint, DimensionOrientationEnum.kHorizontalDim, TextPoint, True) Dim oLineLengthParam As String = oConstraint.Parameter.Name Dim oHoleCenters As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection oHoleCenters.Add(oLine.StartSketchPoint) Dim oPoint As Point = oSketch1.SketchToModelSpace(oTG.CreatePoint2d(oFromLeftEdge, oFromFrontEdge)) Dim oLinearPlacementDef As LinearHolePlacementDefinition = oPartCompDef.Features.HoleFeatures.CreateLinearPlacementDefinition(oFace, oLeftEdge, oFromLeftEdge, oFrontEdge, oFromFrontEdge, oPoint) Dim oDrillDia As String Dim Separators() As Char = {"."c, "-"c} Dim Sentence As String = oLayer Dim Words As Array = Sentence.Split(Separators) Dim i As Integer = 0 For Each wrd In Words If i = 2 Then oDrillDia = "." &(Val(Words(i))) End If i += 1 Next 'specify word splitting characters "space" and "dash" Dim oHoleFeature As HoleFeature = oPartCompDef.Features.HoleFeatures.AddDrilledByThroughAllExtent(oLinearPlacementDef, oDrillDia, kPositiveExtentDirection) oHoleFeature.Name = oHoleName ' Create the object collection. Dim FeatureColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection Dim oHoleFeatureItem As Integer ' Add the newly created hole feature to the collection. For Each oHoleFeature In oPartCompDef.Features.HoleFeatures If oHoleFeature.Name = oHoleName Then Call FeatureColl.Add(oHoleFeature) End If Next Dim oPatternPath As Object = oPartCompDef.Features.CreatePath(oSketch1.SketchLines.Item(4)) ' Create the pattern Dim oPatternFeature As RectangularPatternFeature = oPartCompDef.Features.RectangularPatternFeatures.Add(FeatureColl, oPatternPath, True, oQty, _ 20, PatternSpacingTypeEnum.kFitToPathLength, , , , , , , , , kIdentical) oPatternFeature.Name = oPatternName Dim oSketch2 As PlanarSketch = oPartCompDef.Sketches.Add(oFace, False) Dim oHoleFace As Face = oHoleFeature.Faces.Item(1) Dim oHoleEdge As Edge = oHoleFace.Edges.Item(1) oSketch2.AddByProjectingEntity(oHoleEdge) For Each oPatFace As Face In oPatternFeature.Faces Dim oPatEdge As Edge = oPatFace.Edges.Item(1) oSketch2.AddByProjectingEntity(oPatEdge) Next oSketch2.Name = oSketchLayerName oSketch2.Visible = False If DocumentType = 1 Then For Each oCompOcc In oAsmCompDef.Occurrences Dim oOccName As String = oCompOcc.Name If Not oCompOcc.Name = oSelCompName Then oCompOcc.Enabled = True End If Next End If ' iLogicVb.UpdateWhenDone = True InventorVb.DocumentUpdate() End Sub
