Ilogic code for Sheet metal Lofted flange between 2 sketch
ArunS2DHBM
ArunS2DHBM
I required Ilogic code for a Sheet metal Lofted flange to create a loft between two given sketches.
Michael.Navara
Here is sample in API help.
And here is short sample for your needs
Dim smCompDef As SheetMetalComponentDefinition = ThisDoc.Document.ComponentDefinition
Dim smFeatures As SheetMetalFeatures = smCompDef.Features
Dim sketch1 As PlanarSketch = smCompDef.Sketches(1)
Dim sketch2 As PlanarSketch = smCompDef.Sketches(2)
Dim profile1 As Path = smFeatures.CreatePath(sketch1.SketchLines(1))
Dim profile2 As Path = smFeatures.CreatePath(sketch2.SketchLines(1))
Dim loftedFlangeDefinition = smFeatures.LoftedFlangeFeatures.CreateLoftedFlangeDefinition(profile1, profile2)
smFeatures.LoftedFlangeFeatures.Add(loftedFlangeDefinition)
ArunS2DHBM
Hi @Michael.Navara
Thanks for the solution and its working, I require extra input, where I have total 4 sketches,
2 at the bottom ( circle and rectangle), similarly at the top also.
I want the code to toggle between the different sketches and the loft should create.
for a instance , BottomSketch=Circle, then in bottom it should take sketch1 and TopSketch=Rectangle, then it should take sketch3
other instance BottomSketch=Rectangle, then in bottom it should take sketch2 and TopSketch=Circle, then it should take sketch4
can u help with this, attached an image for your reference.
Thanks in advance
