Component visibility via Document object
chendersonCRKPU
chendersonCRKPU
Is there a way to access the visibility status of a component via the Document object?
I'm looping through the BOMRows enumerator and would like to determine the visibility status of each component.
Or is this only achievable through a Component Occurrences loop?
Andrii_Humeniuk
Hi @chendersonCRKPU . You can't get visibility information in a Document object, you need to use oRow.ComponentOccurrences.Item(1). Example code:
Private Sub Main()
	Dim oDoc As Document = ThisApplication.ActiveDocument
	If TypeOf oDoc Is AssemblyDocument Then
		Dim oAssDoc As AssemblyDocument = oDoc
		If CheckDocMiss(oAssDoc) Then Exit Sub
		Call WorkWithAssembly(oAssDoc)
	Else If TypeOf oDoc Is DrawingDocument Then
		Dim oDrawDoc As DrawingDocument = oDoc
		Dim oAssDoc As AssemblyDocument = oDrawDoc.ReferencedDocuments.Item(1)
	Else
		MessageBox.Show("This rule can only be run in an assembly or a drawing files.", "Error!", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Sub
Private Sub WorkWithAssembly(ByVal oDoc As AssemblyDocument)
	Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Dim oBOM As BOM = oDef.BOM
	Dim oBOMViewStruc As BOMView = GetBOMstructure(oBOM)
	If IsNothing(oBOMViewStruc) Then Exit Sub
	For Each oRow As BOMRow In oBOMViewStruc.BOMRows
		Dim oOcc As ComponentOccurrence = oRow.ComponentOccurrences.Item(1)
		MessageBox.Show("Visible - " & oOcc.Visible, oOcc.Name)
	Next
End Sub
Private Function GetBOMstructure(ByVal oBOM As BOM) As BOMView
	Dim sLanguageBOM, sSortItem As String
	Select Case ThisApplication.LanguageCode
	Case "en-US"
		sLanguageBOM = "Structured"
		sSortItem = "Item"
	Case "ru-RU"
		sLanguageBOM = "Структурированный"
		sSortItem = "Номер"
	Case Else
		Exit Function
	End Select
	If oBOM.StructuredViewEnabled = False Then oBOM.StructuredViewEnabled = True
	If oBOM.StructuredViewFirstLevelOnly = False Then oBOM.StructuredViewFirstLevelOnly = True
	oBOM.BOMViews.Item(sLanguageBOM).Sort(sSortItem, True)
	Return oBOM.BOMViews.Item(sLanguageBOM)
End Function
Private Function CheckDocMiss(ByVal oDoc As Document) As Boolean
	For Each oRefDoc As DocumentDescriptor In oDoc.ReferencedDocumentDescriptors
		If Not oRefDoc.ReferenceSuppressed Then
			If oRefDoc.ReferenceMissing Then
				Return True
	Next
	Return False
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
