iLogic code for exporting all model states in part document
raymaster
raymaster
Hello All
tried to have an ilogic that can export all model states of my part document to a seperate IPT ot X_T files, but it ended in exporting all the models but didnt chage the model state for each one, so they got different names but with the same current model state.
here is the code:
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oFolderName As String
FolderName = InputBox("Insert Folder Name", "Export Folder", oFolderName)
Dim oPath As String = "C:\X_T\" & FolderName ' Change this to the correct path
For Each oState As ModelState In oDoc.ComponentDefinition.ModelStates
    Try
        Dim oXtPath As String = oPath & "\" & oState.Name & ".ipt"
        oDoc.SaveAs(oXtPath, True)
    Catch ex As Exception
        MessageBox.Show("Error processing " & oState.Name & ": " & ex.Message, "iLogic")
    End Try
Next
MessageBox.Show("New Files Created in: " & vbLf & oPath, "iLogic")
A help needed!
m_baczewski
I'm not entirely sure if that's exactly what you were referring to, but it seems to me that you just need to activate the specific model state before saving it. I changed some part of code to myself.
Dim oPath As String = ThisDoc.Path
	Try
		oState.Activate
	End Try
Next
raymaster
I edited it like so and it worked:
    oDoc = ThisDoc.Document
	Dim oPath As String = "C:\Export_ipt\" & FolderName ' Change this to the correct path
    Dim oModelState As ModelState
    For Each oModelState In oDoc.ComponentDefinition.ModelStates
        Logger.Info(oModelState.Name)
        If oModelState.Name <> "Master" Then
            oModelState.Activate
		Try
        Dim oXtPath As String = oPath & "\" & oModelState.Name & ".IPT"
        MessageBox.Show("Error processing " & oModelState.Name & ": " & ex.Message, "iLogic")
    	End Try
    Next
