iLogic Code - Find and Highlight Overridden Balloons
Message 1 of 8
Has anyone found a way to write code like this shown in the link below, but for overridden balloons instead? I have tried many variations and can't even get close.
http://inventortrenches.blogspot.com/2011/06/using-ilogic-to-find-dimension.html (Curtis Waguespack blog - excellent blog)
-------------Start of ilogic ------------------------------------------------
' Set a reference to the active document.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
'Define the drawing dims collection
Dim oDrawingDims As DrawingDimension
'Dim oColor As Inventor.Color
Dim oColor As Color
'Prompt user to choose highlight / un-highlight
Dim booleanParam as Object
booleanParam = InputRadioBox("Select an Option", _
"Hightlight Overrides", "Un-Hightlight Overrides", True, Title := "iLogic")
'Loop through all dimensions and set colors
For Each oDrawingDims In oDoc.ActiveSheet.DrawingDimensions
   If booleanParam = True then
   'set color to magenta
   oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 255)
   else
   'set color to black
   oColor = ThisApplication.TransientObjects.CreateColor(0, 0, 0)
   oColor.ColorSourceType = ColorSourceTypeEnum.kLayerColorSource
   end if
   if oDrawingDims.HideValue = True _
   or oDrawingDims.ModelValueOverridden = True then
   oDrawingDims.Text.Color = oColor
   Else
   End if
Next
'-------------End of ilogic ------------------------------------------------
Replies (7)
Message 2 of 8
dean.morrison
So i don't think you can change the colour of the balloons like the dimensions..
However i changed the prompt to identify if there are overrides, and choose whether or not to fix them.
Also i am unsure how to remove the override completely, instead i made the override match the itemnumber.
Hope it helps.
Dean.
SyntaxEditor Code Snippet
Dim oBalloon As Balloon
For Each oBalloon In oDoc.ActiveSheet.Balloons
   If oBalloon.BalloonValueSets(1).OverrideValue <> "" And oBalloon.BalloonValueSets(1).OverrideValue <> oBalloon.BalloonValueSets(1).ItemNumber Then
   Info = (oBalloon.BalloonValueSets(1).ItemNumber & " overridden with" & oBalloon.BalloonValueSets(1).OverrideValue)
    booleanParam = InputRadioBox(Info , _
    "Fix Override", "Leave Override", True, Title := "iLogic")
    If booleanParam = True Then
       oBalloon.BalloonValueSets(1).OverrideValue = oBalloon.BalloonValueSets(1).ItemNumber
Next
Message 3 of 8
Curtis_Waguespack
Hi huntjw36,
To strip the  overrides we can use just this:
'Loop through all balloons
For Each oBalloon In ThisApplication.ActiveDocument.ActiveSheet.Balloons
	'clear overrides
    oBalloon.BalloonValueSets(1).OverrideValue = ""
Next
I hope this helps.
Curtis
Message 4 of 8
Dean,
 Thank you for your help. I modified the code to work for our application. See below.
'-------------Start Of ilogic ------------------------------------------------
Dim Message As Integer
Dim N As Integer                                        'TOTAL NUMBER OF SHEETS
Dim X As Integer                                        'SHEET NUMBER USED FOR DO LOOP COUNTER
Dim Y As String                                         'SHEET NUMBER AS STRING FOR ACTIVE SHEET PART OF DO LOOP
Dim oDrawing As DrawingDocument
oDrawing = ThisApplication.ActiveDocument
Dim osheet As Sheet
i = 0
'count total sheets
For Each osheet In oDrawing.Sheets
If osheet.ExcludeFromCount = True Then
i = i + 1
Else
Next
'Remove the excluded sheet from the total number of sheets
oMySheetCount = oDrawing.Sheets.Count - i
N = oMySheetCount
X = 1
'---------------------------------------Message Box asking the user if they wish to continue---------------------------------
Message = MessageBox.Show("This Operation Will Check " & N & " Sheets for Overridden Balloons. Press the OK button, if you wish to continue.", "Drawing Dimension Check Operations", MessageBoxButtons.OKCancel, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
If Message = 2 Then
Exit Sub
Else
MultiValue.UpdateAfterChange = True
'Loop through all sheets to find overidden balloons
Do While X <= N
Y = X
ActiveSheet = ThisDrawing.Sheet("Sheet:"&Y)
ThisApplication.ActiveView.Fit                            'ZOOM ALL' Set a reference to the active document.
   Info = "ITEM "&(oBalloon.BalloonValueSets(1).OverrideValue & " SHOULD BE " & oBalloon.BalloonValueSets(1).ItemNumber)
    "FIX THE OVERRIDE?", "LEAVE THE OVERRIDE?", True, Title := "SHEET: "&Y)
Next
X = X+1                                            'COUNTER FOR DO LOOP
Loop
X = 1                                            'RESETTING THE COUNTER
Y = X                                            'RESETTING THE SHEET NUMBER TO THE COUNTER
ActiveSheet = ThisDrawing.Sheet("Sheet:1")
iLogicVb.UpdateWhenDone = True
RuleParametersOutput()
InventorVb.DocumentUpdate()
ThisDoc.Save
Message 5 of 8
In the same way, I have one new balloon report output requirement.
We often work on massive assemblies. The one I am working on has over 14000 parts overall and I am adding 75 unique items to this assembly but some items may have quantities up to 24. All 24 are not in the same location and our internal requirement is to add the same balloon number at different locations with over-ride quantities. So, there may be, lets say, balloon number 8 in 5 different locations. Each may have different over--ridden quantities.
This is very painful to create and manage.
What I am looking to do is to try to run a report of all balloon notes showing individual occurrence of each balloon number and its over-ridden quantity. Then compare it to the total qty in the BOM to see if our manually entered quantities for each balloon adds up to the BOM quantity for that item number.
I can make use of much of your code to identify the balloons with over-rides but I could use lots of help otherwise.
Anyone have this type of need or solution to it? Perhaps our guru  Curtis Waguespack can help?
Thank you.
Message 6 of 8
drafting03_AR
This code works great and does exactly what I was looking for. However, I found that it does not check attached balloons (when you have multiple balloons attached to the same leader) that are overridden. Is there any way to do this?
Message 7 of 8
Curtis_Waguespack
@drafting03_AR
See the example at this link and look at the "i = i+1" portion of the code. This is how we access the attached balloons.
Compare it to MESSAGE 12 OF 18 on that thread. Post 12 is only getting the first level balloons, post 16 is getting all levels.
https://forums.autodesk.com/t5/inventor-forum/inventor-2022-parts-list-balloon-indicating-icons/m-p/...
I hope this helps.
Curtis
Message 8 of 8
maxim.teleguz
@Anonymous wrote:
Dean,
Dim osheet As Sheet
i = 0
'count total sheets
i = i + 1
Else
Next
N = oMySheetCount
X = 1
If Message = 2 Then
Exit Sub
Else
Do While X <= N
Y = X
Next
Loop
ThisDoc.Save
should just fix it to be:
