iLogic code doesn't work anymore
Hi All, I have a iLogic rule for saving drawings (dwg) to a pdf file in a designated folder. Everything worked well until this Monday morning. Now I get the message: Error in rule: Save2PDF, in document: 13006-027 propflens-1.dwg Value cannot be null.
More info in de Error windows says: System.ArgumentNullException: Value cannot be null. Parameter name: path at System.IO.Directory.CreateDirectory(String path) at LmiRuleScript.Main() at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem) at iLogic.RuleEvalContainer.ExecRuleEval(String execRule) And I added the code in a .txt file, but don't see it in the post...
Hi All, Clearly I have changed a variable name... So this issue is solved.
