iLogic code: Conveyour with hangers
Message 1 of 8
So I'm makin a conveyour with hangers on it and I want to add an iLogic rule, that changes the amount of hangers compared to the length of the conveyor
Hanger Distance: Min 600 mm max 1000
Length of the conveyor (Min 150 mm max 6000) ...From 150-500 mm there should be no hangers
I have the followig 2 parameters
Length (Length of the conveyour)
Hanger_Distance (The distance between each hanger. min distance = 600 mm max 1000 mm)
The Hanger is offset from center at Hanger_Distance/2
How would I go about writting the ilogic code for this?
Replies (7)
Message 2 of 8
Thomas_Savage
Could you attach your .ipt please?
So i can have a look.
Thank you.
Thomas Savage
Design Engineer
Message 3 of 8
Here you go
Message 4 of 8
Thomas_Savage
Thank you.
Where do you want you hangers to start and end?
Do you have a distance from the edge where the first and last hanger are placed?
Thomas.
Thomas Savage
Design Engineer
Message 5 of 8
The hanger should either start
from 0, from center of conveyor
or
Hanger_Distance/2 from center (like the .ipt)
If this could be selectable, that'd be nice
Message 6 of 8
Thomas_Savage
Ok.
The only problem is you are using an older version of Inventor than me. I am on 2018.
What version are you using?
Thomas.
Thomas Savage
Design Engineer
Message 7 of 8
yeah, we're still stuck in 2015 here Smiley Indifferent
Message 8 of 8
Thomas_Savage
I could do a Screencast of a easy way to do it. So you can see if this would work for you. So you can copy it easy.
Or when i get home i can see if i have 2015 and attach an .ipt.
Thomas.
Thomas Savage
Design Engineer
