iLogic check iProp from idw, open file and popup box for input
Message 1 of 15
Hi all, i've made an ilogic macro to check the part or assembly description when i made a drawing.
It's triggered when i save.
This is the macro
' Get drawing path
modelFullFileName = ThisDrawing.ModelDocument.FullFileName
Dim oPart As PartDocument
Dim oPartPath As String
Dim sDesc As String        'Variable for Description iProperty
sDesc = iProperties.Value("Project", "Description")
If sDesc = "" Then
MsgBox("DESCRIZIONE MANCANTE")
' Open the target part
ThisApplication.Documents.Open(modelFullFileName)
iLogicVb.RunExternalRule("REGOLA_DESC")
End If
and when it work,at the end open another rule (because in the same rule the input box didn't work for me)
InventorVb.DocumentUpdate()
If sDesc = "" Then
    myparam = InputBox("The Description iProperty is empty" & vbLf & "Please Fill in the File Description", "Missing Description", "")
     iProperties.Value("Project", "Description") = myparam
     ThisDoc.Save
End If
opendoc = ThisDoc.PathAndFileName()'saves doc path and file name
doc = ThisApplication.Documents.Open(opendoc & ".ipt")'saves 'doc' as the open application from 'opendoc' adding the extension '.iam'
doc.Close 'closes the indicated document 'doc'
But if i do all from the first macro, when i write some in the input box and press enter going in error.
But if i run only the second macro , it work.
Someone know why in the first example it doesn't work?
Thank you
Replies (14)
Message 2 of 15
WCrihfield
Here is the code from one of the external iLogic rules I have used in the past, that is to be initiated from the active drawing document, and compares the Title and Description iProperty values from both the Drawing and the Model files, and if there is any differences, it notifies you and asks you what you want to do about it.
And there are 3 pre-defined options to choose from.
  •  Copy the value from the drawing back to the model
  • Copy the value from the model to the drawing
  • Or do nothing (in-case you might want to leave it that way, for some reason.
I think your problems may be stemming from how you are retrieving the iProperty values.  Any time you use iProperty.Value(oPropertySet, oProperty) you are getting that property from the active document (the document that was active when you started the rule).  There is an alternative way of using that line to retrieve iProperty values from components within an active assembly, by including the component as the first of three input variables within the (), but in general, when you want to access the iProperties of other documents, you should always go through the oOtherDoc.PropertySets.PropertySet.Property.Value = .
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
	MessageBox.Show("The Rule named '" & iLogicVb.RuleName & "' attempted to run." & vbCrLf &
	"However, it was terminated because the 'Active Document' is the wrong type fot it to work with." & vbCrLf &
	"It only works for DRAWING DOCUMENTS.", "WRONG DOCUMENT TYPE",MessageBoxButtons.OK, MessageBoxIcon.Error)
	Return
End If
Dim oMDoc As Document = ThisDrawing.ModelDocument
If oMDoc Is Nothing Then
	Return
End If
Dim oDtoM As String = "COPY IT FROM DRAWING TO MODEL"
Dim oMtoD As String = "COPY IT FROM MODEL TO DRAWING"
Dim oDN As String = "DO NOTHING"
Dim oWhatToDo As New ArrayList
oWhatToDo.Add(oDtoM)
oWhatToDo.Add(oMtoD)
oWhatToDo.Add(oDN)
Dim oPropSets As PropertySets = oMDoc.PropertySets
'[ Compare Titles
Dim oInvSumInfo As PropertySet = oPropSets.Item("Inventor Summary Information")
Dim oModelTitle As String = oInvSumInfo.Item("Title").Value.ToString
Dim oDrawingTitle As String = iProperties.Value("Summary", "Title").ToString
If oModelTitle = oDrawingTitle Then
	GoTo Description
ElseIf oModelTitle <> oDrawingTitle Then
	oTitleAns = InputListBox("This Drawing's 'Title' doesn't match the referenced Model File's 'Title'." & vbNewLine &
	"What do you want to do? ", oWhatToDo, oWhatToDo.Item(1), "TITLES DON'T MATCH", "OPTIONS")
	If oTitleAns = "" Then
		GoTo Description
	ElseIf oTitleAns = oDtoM Then
		oMDoc.Save
	ElseIf oTitleAns = oMtoD Then
		oDrawingTitle = oModelTitle
	ElseIf oTitleAns = oDN Then
		GoTo Description
	End If
End If
Description :
'[ Compare Descriptions
Dim oDesTracProps As PropertySet = oPropSets.Item("Design Tracking Properties")
Dim oModelDesc As String = oInvSumInfo.Item("Description").Value.ToString
Dim oDrawingDesc As String = iProperties.Value("Project", "Description").ToString
If oModelDesc = oDrawingDesc Then
	Return
ElseIf oModelDesc <> oDrawingDesc Then
	oDescAns = InputListBox("This Drawing's 'Description' doesn't match the referenced Model File's 'Description'." & vbNewLine &
	"What do you want to do?", oWhatToDo, oWhatToDo.Item(1), Title := "DESCRIPTIONS DON'T MATCH", ListName := "OPTIONS")
	If oDescAns = "" Then
		Return
	ElseIf oDescAns = oDtoM Then
		oMDoc.Save
	ElseIf oDescAns = oMtoD Then
		oDrawingDesc = oModelDesc
	ElseIf oDescAns = oDN Then
		Return
	End If
End If
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 15
Yes, the problem is getting that property from the active document and i use
to "update" the document info, but it don't work.
I try your macro now
Message 4 of 15
Error for me
Message 5 of 15
WCrihfield
Everyone's system & settings are different, so changed a few little things within the code that may help.
See if this variation works better for you.  And if it doesn't, could you please include the screen shot of both tabs within the error message?  Often the second tab (more info) is more informational and may help me better understand the error.
	MsgBox("This rule only works when started from a drawing document. Exiting.",vbOKOnly + vbExclamation,"WRONG DOCUMENT TYPE")
	Return
End If
If ThisDrawing.ModelDocument Is Nothing Then
	MsgBox("No Model Document was found for the active drawing. Exiting.",vbOKOnly + vbExclamation,"NO MODEL")
	Return
End If
oWhatToDo.Add(oDN)
	GoTo Description
	oTitleAns = InputListBox("This Drawing's 'Title' doesn't match the referenced Model File's 'Title'." & vbCrLf &
		GoTo Description
		oMDoc.Save
		GoTo Description
	End If
End If
Description :
	Return
	oDescAns = InputListBox("This Drawing's 'Description' doesn't match the referenced Model File's 'Description'." & vbCrLf &
	"What do you want to do?", oWhatToDo, oWhatToDo.Item(1), "DESCRIPTIONS DON'T MATCH", "OPTIONS")
		Return
		oMDoc.Save
		Return
	End If
End If
Also, make sure that within the Options tab for that iLogic rule in the Rule Editor, the "Straight VB code" is not checked, and that the "Silent operation" option is checked.
Wesley Crihfield
Message 6 of 15
WCrihfield
Also, it appears that your error message is in Italian.  So if your Inventor and iLogic Rule Editor is also set to use Italian language within, you may have to translate some of it before you can use it.
Wesley Crihfield
Message 7 of 15
This is error from your second macro
Message 8 of 15
Anh ok, i try
Message 9 of 15
WCrihfield
OK. It was having problems finding the Property.
Try this:
	Return
End If
	Return
End If
oWhatToDo.Add(oDN)
If oInvSumInfo.Item("Title").Value = "" Or oInvSumInfo.Item("Title").Value = vbNullString Then
	oModelTitle = ""
Else
	oModelTitle = oInvSumInfo.Item("Title").Value
End If
If iProperties.Value("Summary", "Title") = "" Or iProperties.Value("Summary", "Title") = vbNullString Then
	oDrawingTitle = ""
Else
	oDrawingTitle = iProperties.Value("Summary", "Title")
End If
	GoTo Description
		GoTo Description
		oMDoc.Save
		GoTo Description
	End If
End If
Description :
If oDesTracProps.Item("Description").Value = "" Or oDesTracProps.Item("Description").Value = vbNullString Then
	oModelDesc = ""
Else
	oModelDesc = oDesTracProps.Item("Description").Value
End If
If iProperties.Value("Project", "Description") = "" Or iProperties.Value("Project", "Description") = vbNullString Then
	oDrawingDesc = ""
Else
	oDrawingDesc = iProperties.Value("Project", "Description")
End If
	Return
		Return
		oMDoc.Save
		Return
	End If
End If
Wesley Crihfield
Message 10 of 15
It work! But just a point:
my drawing in "cartiglio" get description from part i put in to make the views. How can i check in the drawing if the part (ipt o iam) of the views have description blank and how i can write it from drawing to part?
Thank you, youre the man!
Message 11 of 15
WCrihfield
OK. Try something like this:
	Return
End If
Dim oDDoc As DrawingDocument = ThisDrawing.Document
	oDrawingDesc = ""
Else
End If
Dim oSheet As Sheet
Dim oView As DrawingView
'Dim oRefDoc As Document
Dim oMPropSet As PropertySet
For Each oSheet In oDDoc.Sheets
	For Each oView In oSheet.DrawingViews
		Dim oRefDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
		oMPropSet = oRefDoc.PropertySets.Item("Design Tracking Properties")
		If oMPropSet.Item("Description").Value = "" Or oMPropSet.Item("Description").Value = vbNullString Then
			oModelDesc = ""
		Else
			oModelDesc = oMPropSet.Item("Description").Value
		End If
		If oDrawingDesc <> oModelDesc Then
			oAns = MsgBox("The Description of the Drawing doesn't match the Model." & vbCrLf & _
			"Do you want to copy the Model Description to the Drawing?", vbYesNo + vbQuestion, "DESCRIPTION MIS-MATCH")
			If oAns = vbYes Then
				iProperties.Value("Project", "Description") = oModelDesc
			End If
		End If
	Next
Next
Wesley Crihfield
Message 12 of 15
No error and nothing appen :V
How can i debug it to show why macro doesn't do nothing?
Message 13 of 15
WCrihfield
@Anonymous
That last code shows you how to get to the document being represented within each view, but if you have multiple model files being represented within the active drawing file, you will want to somehow find which model you want to copy the description from, so it doesn't copy if from each one, for every view.
If you have a specifically named sheet & view or, just want to get the first sheet & first view, that would be easier, then you could avoid looping through all the sheets and all the views within each sheet.  Then it would only copy data one time.
Wesley Crihfield
Message 14 of 15
WCrihfield
This is about as simple as I can make the code to copy the model's description to the drawings description, while getting the model document from a view, rather than the main model of the drawing.
I included comments above each line of code explaining what is going on.
You'll notice I am using the iProperties.Value method this time, to help simplify, but I'm not certain it will work without the mode file open, so I have a couple of lines commented out within the code, that would open the model file before attempting to access its iProperties, then a line to close it again at the end.  If the iProperties.Value() line fails, try un-commenting those two lines.
'Getting the description of the active drawing document, without checking if it is empty
'Getting the active sheet of the active drawing
Dim oSheet As Sheet = oDDoc.ActiveSheet
'Getting the first view that was placed into the drawing (you could specify the drawings name here too inside "" marks)
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
'Getting the document being represented within the view
Dim oVDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
'ThisDoc.Launch(oVDoc.FullFileName)
'Getting the model documents description iProperty value the shorter way, without checking if it is empty
Dim oVDesc As String = iProperties.Value(oVDoc, "Project", "Description")
'comparing both descriptions   <> means 'does not equal'
If oDrawingDesc <> oVDesc Then
	'attampts to set the active drawings description value to the value of the models description
	iProperties.Value("Project", "Description") = iProperties.Value(oVDoc, "Project", "Description")
End If
'oVDoc.Close
Wesley Crihfield
Message 15 of 15
It work! Thank you
