iLogic change the text for an existing symbol
dusan.naus.trz
Advisor Advisor
dusan.naus.trz
How can I use ilogic to change the text for an existing symbol? No use of the text prompted entry.
Sketched Symbols Name = example
Sketched Symbols Text = test1
After using ilogic Change Sketched Symbols Text = test2
Thank you for answer.
rhasell
Hi
I got the following bit of code from Curtis Waguespack. The only change I made from his original code is the loop at the end.
It will change everything based on your search string, but perhaps you can change it to suit your needs?
Sub MAIN ()
oDoc = ThisDoc.Document
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim oGeneralNotes As GeneralNotes
Dim oGeneralNote As GeneralNote
Dim oSymbol As SketchedSymbol
Dim oSymbols As SketchedSymbols
Dim oTitleBlock As TitleBlock
'Dim oTestBox As TextBox
Dim TXT2Find As String
Dim NewTXT As String
'get user input
TXT2Find = InputBox("Enter Text To Find:", "iLogic", "XXX")
'look for blank value
If TXT2Find ="" Then
Return 'exit rule
Else
'Continue rule
End If
NewTXT = InputBox("Enter Text To Replace   '"& TXT2Find _
& "'  with.", "iLogic", "****")
If NewTXT ="" Then
Return 'exit rule
Else
'Continue rule
End If
oSheets = oDoc.Sheets
For Each oSheet In oSheets
	'handle errors
	On Error Resume Next
	'look at gerenal notes
	oGeneralNotes = oSheet.DrawingNotes.GeneralNotes
	For Each oGeneralNote In oGeneralNotes
		If oGeneralNote.FormattedText = TXT2Find Then
		oGeneralNote.FormattedText = NewTXT
		Else
		End If
	Next
	'look at leader notes
	oLeaderNotes = oSheet.DrawingNotes.LeaderNotes
	For Each oLeaderNote In oLeaderNotes
		If oLeaderNote.FormattedText = TXT2Find Then
		oLeaderNote.FormattedText = NewTXT
		Else
		End If
	Next
	'look at title blocks
	oTitleBlock = oSheet.TitleBlock
	For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
        	If oTitleBlock.GetResultText(oTextBox) = TXT2Find  Then
        	oTitleBlock.SetPromptResultText(oTextBox, NewTXT )
		Else
		End If
    	Next
	'look at sketched symbols
	oSymbols = oSheet.SketchedSymbols
    	For Each oSymbol In oSymbols
    		For Each oTextBox  In oSymbol.Definition.Sketch.TextBoxes
 			If oSymbol.GetResultText(oTextBox) = TXT2Find Then
 			oSymbol.SetPromptResultText (oTextBox, NewTXT)
    			Else
			End If
    		Next
        Next
Next
oAgain=MessageBox.Show("Again", "Rinse and Repeat",MessageBoxButtons.YesNo, MessageBoxIcon.Question) 'Added rev2
If oAgain=vbYes
AGAIN
End If
End Sub
Sub AGAIN
MAIN
End Sub
Reg
2026.1
dusan.naus.trz
No, that's not the solution. This is not the case in the introduction.
