Ilogic Change Parameter in any Part that is not a component
can you tell what i want to do here. the commented code does not work.
i want to be able to open a part and change its size parameters before i open the assembly. this code will run as an external rule in a new empty file.
if i can do it without opening the part, that is even better.
'test can i open a part, change a param, then close part
Dim fname As String
fname ="C:\Workspace\my_prog\chan\F_BB_L.ipt"
Dim pDoc as PartDocument = ThisApplication.Documents.Open(fname,False)
pDoc  = ThisApplication.Documents.Open(fname)
' these are just attempts to find a syntax that works
' i need the method to change the parameter
 'param = pDoc.PartComponentDefinition.Parameter.Param("TKNS")
 'pdoc.parameter.Param("TKNS") = 8
pdoc.Save
pdoc.Close
jdkriek
Here you go:
Dim fName As String = "C:\Workspace\my_prog\chan\F_BB_L.ipt"
Dim pDoc as PartDocument = ThisApplication.Documents.Open(fName, False)
pDoc.ComponentDefinition.Parameters.Item("TKNS2").Value = 8
pDoc.Update
pDoc.Save
pDoc.Close
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
thanks!
but,
gives result in cm,
the parameter is in inches.
8 / 0.39370 gives a result in inches, with errors in the 5th place,
what is the standard way to input 8"?
thanks again.
MegaJerk
Perhaps multiplying it would fix the problem
pDoc.ComponentDefinition.Parameters.Item("TKNS2").​Value = (8*2.54)
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
here it is
pDoc.ComponentDefinition.Parameters.Item("TKNS").Expression = "8 in"
