Message 1 of 11
Ilogic Center and Arrange dimensions but exclude dimensions under an angle
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have following code for centering and arranging my dimensions.
Sub Main Dim oDoc As DrawingDocument oDoc = ThisDoc.Document ' Set a reference to the active sheet Dim oSheet As Sheet oSheet = oDoc.ActiveSheet Dim oDrawingDim As DrawingDimension Dim oDrawingDims As DrawingDimensions Dim oDimsToBeArranged As ObjectCollection ' Iterate over all dimensions in the drawing and ' center them if they are linear or angular. ' Add them to the ObjectCollection to be arranged oDrawingDimensions = oSheet.DrawingDimensions oDimsToBeArranged = ThisApplication.TransientObjects.CreateObjectCollection For Each oDrawingDim In oDrawingDimensions If TypeOf oDrawingDim Is LinearGeneralDimension Then oDrawingDim.CenterText oDimsToBeArranged.Add(oDrawingDim) End If Next If oDimsToBeArranged.Count > 0 Then oDrawingDimensions.Arrange(oDimsToBeArranged) End If End Sub
I have 2 things i want to add:
1) i want to be able to center an ordinate set also?
2) i have some dimensions under an angle and i want to exclude these angles. Is this possible? (see picture)
Hope some of you can help me out with this one.
