Ilogic - cant get view properties to populate into sketch symbol
ahobby
ahobby
Trying to get a view information to populate the prompted fields of a sketch symbol.
It works for selecting the view, but once I select the sketch label I want I get the following error:
Public member 'TextBoxes' on type 'SketchedSymbol' not found.
Any help would be highly appreciated... drawing file attached to laugh at.
SyntaxEditor Code Snippet
Dim doc as DrawingDocument
doc = ThisApplication.ActiveDocument
Dim oSymbol As SketchedSymbol
Dim oViewName As String
'choose the view we want to grab properties from
Dim oObj As Object
oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter,"Select a view:")
    If oObj Is Nothing Then
        Else
        'get the view name
        Dim viewName As String = oObj.Name
        'send the view label name back to the public variable oViewName
        oViewName = viewName
    End If
'change the result text of the selected SketchedSymbol
Dim oSS As SketchedSymbol
'choose the sketch symbol we want to inject text strings into fields of
'oSS=ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchBlocksFilter,"Select a Label:")
oSS=ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingsketchedSymbolFilter,"Select a Label:")
'if our sketched symbol name is named ITEM8 then do the actions
    If oSS.Definition.Name = "ITEM8" Then
            Dim oEachText As TextBox
            Dim I
                For I = 1 To oSS.TextBoxes.Count
                oEachText = oSS.TextBoxes(I)
                    If (oEachText.Text = "NAME") Then
                    oNewResultText = oEachText
                    End If
                Next
        Else
    End If
JaneFan
Hello @ahobby
There is no TextBoxes member in SketchedSymbol object. Please try to replace oSS.TextBoxes with following one if SketchedSymbol is picked:
oSS.Definition.Sketch.TextBoxes
Jane Fan
Inventor/Fusion QA Engineer
dgreatice
see my attachment, try to add you own base view, then add my sketch symbols "MY ITEM".
try my example code:
Dim App As Application
App = ThisApplication
Dim oDV As DrawingView
oDV = App.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select View:")
Dim SktSymb As SketchedSymbol
Dim oTB As TextBox
For Each SktSymb In oDV.Parent.SketchedSymbols
If LCase(SktSymb.Name) = LCase("MY ITEM") Then
For Each oTB In SktSymb.Definition.Sketch.TextBoxes
If LCase(oTB.Text) = LCase("<TEXT>") Then
Call SktSymb.SetPromptResultText(oTB, "Hello World")
End If
Next
End If
Next
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
ahobby
@dgreatice
THANK YOU!
Your code snippet was just what I needed to fix it - I've been playing with this code for a week trying to get it to do what I wanted.
I tweaked it a little bit to not automatically hunt through each sketch symbol, but instead let the user select the symbol:
Dim oTB As TextBox
SktSymb=ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingsketchedSymbolFilter,"Select a Label:")
'if our sketched symbol name is named ITEM8 then do the actions'    If SktSymb.Definition.Name = "ITEM8" Then'For Each SktSymb In oDV.Parent.SketchedSymbols
    If LCase(SktSymb.Name) = LCase("ITEM8") Then
            If LCase(oTB.Text) = LCase("NAME") Then
                Call SktSymb.SetPromptResultText(oTB, oDV.Name)
            End If
        Next
    End If
'Next
