iLogic - Bom / Part list in Drawing document. Create, edit and delete
Message 1 of 27
First post here, but needed at this time. I tried to find a solution searching again and again on the web, without success.
Working on Inventor Professional 2015 SP2 Build 223
I'm working on an iLogic rule to create a BOM which will be exported in an excel template.
I have multiple problems :
Problem 1 :
I can't create a BOM if there isn't one already.
My code, is very basic :
iLogicVb.UpdateWhenDone = True
Dim ThisDrawDoc As DrawingDocument = Nothing
ThisDrawDoc = ThisApplication.ActiveDocument
ThisSheet = ThisDrawDoc.ActiveSheet
Dim DrawingPartList As PartsLists = ThisSheet.PartsLists
Dim BomPlacementPoint As Point2d
Dim SheetBorder As Border
SheetBorder = ThisSheet.Border
BomPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(0, SheetBorder.RangeBox.MaxPoint.Y)
DrawingPartList.Add(ThisDrawingView,BomPlacementPoint)
If a part list already exist, it works fine. But if there is no part list, I have this error prompting :
Erreur de règle: math_BOM - Export de liste de piece client, dans le document assemblage.idw
Paramètre incorrect. (Exception de HRESULT : 0x80070057 (E_INVALIDARG))
I don't know why the argument is not valid. It's very strange.
Did anyone already have this problem?
Problem 2 :
I want to be able to delete the BOM I just create with the rule.
I didn't find the function of the class PartsLists.
I guess it's something like that :
DrawingPartList.Delete.Item(DrawingPartList.count)
But it doesn't work.
Is there a documentation where I can find class descriptions of Inventor? Like every functions of class PartsLists?
Thanks!
Math
Replies (26)
Message 2 of 27
Curtis_Waguespack
Hi @Anonymous,
Welcome to the forums.
Note that future programming questions of this type are better placed on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
Also here are some programming help links:
I hope this helps.
Curtis
Here is a sample ilogic rule that addresses your questions with the parts list:
Dim ThisSheet As Sheet
Dim oPartsList As PartsList
Dim oView As DrawingView
Try
	'Try to get the first view on the sheet
	oView = ThisSheet.DrawingViews(1)
Catch
	'catch error when no view exists
	'and exit rule
	MessageBox.Show("View not found", "ilogic")
	Return
End Try
Try
	'try to get the first parts list
	'in the PartsLists collection
	oPartsList = ThisSheet.PartsLists.Item(1)
Catch
	'catch error when no parts list is found
	'and then create one
	oPartsList = ThisSheet.PartsLists.Add(oView,BomPlacementPoint)
End Try
oQuestion = MessageBox.Show("Do you want to delete the parts list", "iLogic",MessageBoxButtons.YesNo)
If oQuestion = vbYes Then
	oPartsList.Delete
End If
Message 3 of 27
Curtis_Waguespack
Message 4 of 27
Thanks for your answer.
Unfortunately, I also have the problem with your code.
I have the same error when I run your rule if there is no PartList in the drawing.
Message 5 of 27
mcgyvr
His code works just fine for me.. (in Inventor 2019 though but I don't think much has changed there with this basic stuff)
Are you sure you aren't running the old rule or something?
Does your drawing have a proper border defined/placed?
Did you place a base view on the drawing already? (try should show an error for that though)
break the code up into sections and try a bit at a time to see which part is causing the error..
Remove the whole second "try/catch" and see if it errors out then..
Message 6 of 27
I found where the problem comes from.
I activate in my assembly template the Structured Tab of the BOM by default, to avoid activate it each time.
I seems to cause the problem.
I modified my template, and even if I activate the Structured Tab after creating my assembly but before creating the BOM with the iLogic rule, the code won't work.
Is there a way to avoid that?
Can I deactivate the Structured Tab of the assembly from the drawing with iLogic and activate it again after creating the BOM?
Message 7 of 27
Curtis_Waguespack
Hi @Anonymous,
Ahhh, so I think you will want to specify the BOM structure in the partslist.add line, see the example below.
Edit: to note that I've asked someone at Autodesk to take a look, as the behavior seems a bit incorrect here, to me.
Note that this example tries to use the kStructured ( First Level) enum, and then uses All Levels
PartsList.Add Reference link:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-64121FC0-E936-4A2B-9F84-46D9BD5701EC
PartsListLevelEnum Enumerators
Name Value Description
kFirstLevelComponents 46593 First level components.
kPartsOnly 46594 Parts only.
kStructured 46593 Structured first level components.
kStructuredAllLevels 46595 Structured all components.
I hope this helps.
Curtis
Try
Catch
	'and exit rule
	Return
End Try
Try
Catch
	Try 'try structured 1st level
		oPartsList = ThisSheet.PartsLists.Add _
		(oView,BomPlacementPoint,PartsListLevelEnum.kStructured)
	Catch 'catch error and try all levels
		(oView,BomPlacementPoint,PartsListLevelEnum.kStructuredAllLevels)
	End Try
End Try
	oPartsList.Delete
End If
Message 8 of 27
Curtis_Waguespack
Hi @MjDeck,
Can you take a look at this discussion and comment about the issue that arises when the assembly BOM is edited and closed with the Structured tab active. This seems to cause and error with the code when the "optional" parts list level enum is not specified.
If the assembly BOM is edited and closed with the Model Data tab active, then it seems that the optional enum is not required.
Can you determine if this is behaving as designed?
I hope this helps.
Curtis
Message 9 of 27
Thanks a lot @Curtis_Waguespack! In the same time, you resolve my next step in my rule!
In fact, I wanted to use the kPartsOnly from the beginning.
But... (there is always a but 🙂 )
If a BOM already exist, the PartsListLevelEnum Enumerators in oPartsLists.Add(oDrawingView,BomPlacementPoint,PartsListLevelEnum.kPartsOnly) is not use.
The PartsList use the PartsListLevelEnum of the existing BOM.
Is there a workaround?
Message 10 of 27
Curtis_Waguespack
Hi @Anonymous,
Try this version, it looks at the drawing view, gets the model referenced in the view, then gets the BOM object from the model, and then sets the BOM view to use partsonly, then specifies the partsonly enum when adding the partslist.
I hope this helps.
Curtis
Dim oBOM As BOM
Try
	'get the model that the veiw is looking at
	oModelDoc = ActiveSheet.View(oView.Name).ModelDocument
	'get the BOM object from the model
	oBOM = oModelDoc.ComponentDefinition.BOM
	'set the BOM to use parts only
	oBOM.PartsOnlyViewEnabled = True
Catch
	'and exit rule
	Return
End Try
Try
Catch
	(oView,BomPlacementPoint, PartsListLevelEnum.kPartsOnly)
End Try
	oPartsList.Delete
End If
Message 11 of 27
Curtis_Waguespack
@Anonymous
Note that my original example answered your questions in the order asked simply to serve as an example, but this version likely handles the removing of an existing parts list and adding a new one it a more real world manner:
Dim oBOM As BOM
Try
Catch
	'and exit rule
	Return
End Try
Try
	'set flag
	oNoPartList = False
	oQuestion = MessageBox.Show _
	("Do you want to delete the existing parts list, and place a new one?", _
		oPartsList.Delete
		'set flag
		oNoPartList = True
	End If
Catch
	'set flag
	oNoPartList = True
End Try
'add parts list if none exists
If oNoPartList = True Then
End If
Message 12 of 27
I tried oyur solution, but it doesn't seem to work.
Maybe I should clarify the goal, to avoid complexity (but everything you did was useful) :
1. Create a new BOM using partsonly level, whether of not a BOM already exist and and it exists, wathever its level.
2. Export the BOM (next step, not the subjet of this post)
3 Delete the table
So here is my rule, without the export part :
' CREATE TABLE
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
oSheet = oDrawDoc.ActiveSheet
Dim oBOM As BOM
Dim oPartsLists As PartsLists
Try
	oView = oSheet.DrawingViews(1)
Catch
	MessageBox.Show("There is no view in the drawing", "Export du dessin", MessageBoxButtons.OK, MessageBoxIcon.Error)
	Return
End Try
'get the model that the view is looking at
'Try to get the PartsLists collection
oPartsLists = oSheet.PartsLists
'Setting BOM position
Dim oBorder As Border = oSheet.Border
BomPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(0, oBorder.RangeBox.MaxPoint.Y)
'Create BOM
Dim BOMexport As PartsList
BOMexport = oPartsLists.Add(oView,BomPlacementPoint,PartsListLevelEnum.kPartsOnly)
' EXPORT TABLE
' DELETE TABLE
	BOMexport.Delete
	If Debug = True Then
		MessageBox.Show("BOM supprimée", "Debug", MessageBoxButtons.OK, MessageBoxIcon.Warning)
	End If
End If
The problem is that the BOM doesn't use the PartsListLevelEnum even with your previous modifications.
Message 13 of 27
Curtis_Waguespack
Hi @Anonymous,
I suspect it is using the PartsOnly view to create the parts list, but you are not seeing it do anything in the assembly BOM, because as written the only thing it does to the BOM is ensure that that PartsOnly view is enabled, but it is not disabling the structured views.
Note that you can have a Structured view enabled and the PartsOnly view enabled at the same time with no issues. You simply set the parts list to be created using the PartsOnly view if that is what you intend to use. Then when you export the partslist, the BOM view that was used when the part list was created is what gets exported.
I hope this helps.
Curtis
Message 14 of 27
I understand that this part of the code :
is just there to assure that the PartsOnly view is active in the Assembly.
But, even if it's active, if I use :
The BOMexport still use the Structured view and not the PartsOnly view if another BOM already exist in the drawing.
The existing BOM should not have an impact on the newly created BOM.
That's the point I don't understand.
Message 15 of 27
Curtis_Waguespack
Hi @Anonymous,
okay, let's first clarify some terminology:
BOM = the internal database of the assembly
Parts List = the table on the drawing that is "looking at" the BOM
In this code the goal is not to export the BOM, but instead to export the Parts List.
The code looks at the BOM (database) only to ensure the PartsOnly view of it is enabled.
Then it uses that PartsOnly  view of the database, when creating the Parts List (table )
And then eventually it will grab the Parts List (table ) and export it to Excel, just as it is... meaning it will export it using the PartsOnly view.
So even though the BOM (database) could have multiple views enabled, the PartsList.Add line is telling it which view to use via the enumerator kPartsOnly. So the table gets created as Parts Only, and therefore when we export the table, that is what we will get.
I hope this helps.
Curtis
Message 16 of 27
Ok, I was confuse with the terminology.
So here my previous comment with the right terminology :
is just there to assure that the PartsOnly view is active in the Assembly BOM. So we can use this BOM view to create our part list.
PartsListToExport = oPartsLists.Add(oView,BomPlacementPoint,PartsListLevelEnum.kPartsOnly)
The PartsListToExport still use the Structured view and not the PartsOnly view of the BOM if another PartsList already exist in the drawing.
The existing PartsList should not have an impact on the newly created PartsList.
What I meant is I don't understand why the option PartsListLevelEnum is not considered when I create the parts list "PartsListToExport"
I hope I will make me understood as english is my second language. But I think we are close to find the solution.
Message 17 of 27
Curtis_Waguespack
Hi @Anonymous,
If you are only placing the parts list, just for export, and do not want it on the sheet in the end, then it might better to export directly from the BOM (database).
See this link for an example:
https://www.cadlinecommunity.co.uk/hc/en-us/articles/212849309-Inventor-2017-iLogic-Quick-BOM-Export
I hope this helps.
Curtis
Message 18 of 27
Curtis_Waguespack
Hi @Anonymous,
Your english is great, don't worry about that.
I think I now understand the problem now. If you already have a parts list on your drawing, then all parts lists will use the same BOM view, this is just the way Inventor works, otherwise balloons would get confused.
As currently written, your code is just placing another parts list without looking to see if one exists already
Do you want to check if one  exists first, and replace it?
I hope this helps.
Curtis
Message 19 of 27
Curtis_Waguespack
Hi @Anonymous,
So here is an example code that looks for an existing parts list   all existing parts lists , deletes them, then places a new one that is PartsOnly.
I hope this helps.
Curtis
' CREATE TABLE
Dim oBOM As BOM
Try
Catch
	MessageBox.Show("There is no view in the drawing", _
	Return
End Try
'get the BOM database oBOM = oModelDoc.ComponentDefinition.BOM ' Make sure the BOM view is enabled oBOM.PartsOnlyViewEnabled = True 'get the PartsLists collection oPartsLists = oSheet.PartsLists 'clean up existing parts lists For Each oPartsList In oPartsLists oPartsList.Delete Next 'Setting BOM position Dim BomPlacementPoint As Point2d Dim oBorder As Border = oSheet.Border BomPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d _ (0, oBorder.RangeBox.MaxPoint.Y) 'Create new partsList oPartsList = oPartsLists.Add(oView,BomPlacementPoint,PartsListLevelEnum.kPartsOnly) iLogicVb.UpdateWhenDone = True ' EXPORT TABLE ' DELETE TABLE oQuestion = MessageBox.Show("Do you want to delete the parts list", "iLogic",MessageBoxButtons.YesNo) If oQuestion = vbYes Then oPartsList.Delete If oDebug = True Then MessageBox.Show("BOM supprimée", "Debug", MessageBoxButtons.OK, MessageBoxIcon.Warning) End If End If
Message 20 of 27
Thank you @Curtis_Waguespack, it's very clear now why I can't do what I want.
It makes sense that I can't create a new parts list with a view different from the existing parts list.
So I will change the purpose of the rule to export the PartsOnly parts list from the assembly, and not from the assembly drawing.
I wanted to give the user the opportunity to keep the PartsOnly part list in his drawing for archive purpose.
