Ilogic Boiler wall panel
Hello
I am trying to build an ilogic the can parametric control a assembly of a wallpanel for a boiler. I am using a Skeletal modelling teknik to build the model and sync/update that into to the assembly.
But the catch is following:
1. If the Cladding is on , then the Slit Cutout shall be in every middle fines and if the Cladding is covering the Slit Cutout then the Slit Cutout has to cut through the cladding also.
2. If the Cladding is off, then the Slit Cutout shall be in every second middle fin if the Cladding is covering the Slit Cutout then the Slit Cutout has to cut through the cladding also.
The code:
'Parameter panel from skelet model
Parameter("test_skeletmodel:1", "Totalheight") = Panelheight
Parameter("test_skeletmodel:1", "pitch") = Pitch
Parameter("test_skeletmodel:1", "tubes") = Tubes
Parameter("test_skeletmodel:1", "Vertical_section")=Verticalsection
Parameter("test_skeletmodel:1", "Tube_Bend_radius")=panelbendradius
Parameter("test_skeletmodel:1", "deduction")=Deduction
'Parameter fin slit from skeletmodel
Parameter("test_skeletmodel:1", "pitch_left_side") = Fin_width_left
Parameter("test_skeletmodel:1", "pitch_right_side") = Fin_width_left
'Parameter tube material and certifikat
iProperties.MaterialOfComponent("test_tube:1") = Tube_material
'Parameter tube Certifikat
MultiValue.SetListInComponent("test_tube:1", "Cert", "EN10204-2.2", "EN10204-3.1", "EN10204-3.2")
Parameter("test_tube:1", "Cert") = Tube_Material_Certifikat
'Parameter tube dimension data
Parameter("test_skeletmodel:1", "Tubediameter") = pipediameter
Parameter("test_skeletmodel:1", "Tube_wall_thickness") = pipethickness
Parameter("test_skeletmodel:1", "Pipechamfer") = Tube_end_chamfer
'Chanfer on tubes yes or no
If Tube_end_chamfer = False
Feature.IsActive("test_skeletmodel:1", "Topchamfer_pipe") = False
Feature.IsActive("test_skeletmodel:1", "bottomchamfer_pipe") = False
Else If Tube_end_chamfer = True
Feature.IsActive("test_skeletmodel:1", "Topchamfer_pipe") = True
Feature.IsActive("test_skeletmodel:1", "bottomchamfer_pipe") = True
'Parameter fines on/off
Parameter("test_skeletmodel:1", "Fin_thickness") = finthickness
Parameter("test_skeletmodel:1", "fin_cutout") = fincutoutlength
'Parameter("Test_fin:1", "Fin_slit_YesNO") = Fin_slit_end
'If Fin_slit_end = False
'Feature.IsActive("Pattern_finslit_bottom") = False
'Feature.IsActive("Pattern_finslit_top") = False
'Feature.IsActive("Finslit_Cutout_bottom") = False
'Feature.IsActive("Finslit_Cutout_top") = False
'Else If Fin_slit_end = True
'Feature.IsActive("Pattern_finslit_bottom") = True
'Feature.IsActive("Pattern_finslit_top") = True
'Feature.IsActive("Finslit_Cutout_bottom") = True
'Feature.IsActive("Finslit_Cutout_top") = True
'End If
'Parameter fines configuration inconel yes/no
'If Internal_Cladding = True Or External_Cladding = True
'Parameter("Fin_slit_numbers") = Tubes - 1
'Parameter("Fin_Slit_pitch") = Pitch
'Parameter("Fin_slit_numbers") = Tubes-1
'Else If Internal_Cladding = False Or External_Cladding = False
'Parameter("Fin_slit_numbers") = Round((Tubes - 1) / 2)
'Parameter("Fin_Slit_pitch") = Pitch * 2
'End If
'fin left side configuration
If Leftside_fin_configuration = "None" Then
Feature.IsActive("test_skeletmodel:1", "Chamfer1left") = False
Feature.IsActive("test_skeletmodel:1", "Chamfer2left") = False
Feature.IsActive("test_skeletmodel:1", "Chamfer3left") = False
Else If Leftside_fin_configuration = "Chamfer1"
Feature.IsActive("test_skeletmodel:1", "Chamfer1left") = True
Else If Leftside_fin_configuration = "Chamfer2"
Feature.IsActive("test_skeletmodel:1", "Chamfer2left") = True
Else If Leftside_fin_configuration = "Chamfer3"
Feature.IsActive("test_skeletmodel:1", "Chamfer3left") = True
'fin equal check
'If Equal_end_fins = True
'Then Leftside_fin_configuration = Rightside_fin_configuration And Rightside_fin_configuration = Leftside_fin_configuration
'Else If Equal_end_fins = False
'Then Leftside_fin_configuration = Leftside_fin_configuration And Rightside_fin_configuration = Rightside_fin_configuration
'End If
'fin right_side configuration
If Rightside_fin_configuration = "None" Then
Feature.IsActive("test_skeletmodel:1", "Chamfer1right") = False
Feature.IsActive("test_skeletmodel:1", "Chamfer2right") = False
Feature.IsActive("test_skeletmodel:1", "Chamfer3right") = False
Else If Rightside_fin_configuration = "Chamfer1"
Feature.IsActive("test_skeletmodel:1", "Chamfer1right") = True
Else If Rightside_fin_configuration = "Chamfer2"
Feature.IsActive("test_skeletmodel:1", "Chamfer2right") = True
Else If Rightside_fin_configuration = "Chamfer3"
Feature.IsActive("test_skeletmodel:1", "Chamfer3right") = True
'Parameter Cladding
Parameter("Test_skeletmodel:1", "cladding_cutout") = Free_lenght_cladding
'Cladding on/off
'Inner Cladding
Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_inner") = False
Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_inner:pattern") = False
Feature.IsActive("test_skeletmodel:1", "Cladding_fin_inner") = False
Feature.IsActive("test_skeletmodel:1", "Cladding_fin_inner_pattern") = False
Feature.IsActive("test_skeletmodel:1", "Cladding_LFIN_T1_inner") = False
Feature.IsActive("test_skeletmodel:1", "Cladding_RFIN_T1_inner") = False
Else If Internal_Cladding = True
Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_inner") = True
Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_inner:pattern") = True
Feature.IsActive("test_skeletmodel:1", "Cladding_fin_inner") = True
Feature.IsActive("test_skeletmodel:1", "Cladding_fin_inner_pattern") = True
Feature.IsActive("test_skeletmodel:1", "Cladding_LFIN_T1_inner") = True
Feature.IsActive("test_skeletmodel:1", "Cladding_RFIN_T1_inner") = True
'Outer Cladding
If External_Cladding = False
Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer") = False
Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer_pattern") = False
Feature.IsActive("test_skeletmodel:1", "Cladding_fin_outer") = False
Feature.IsActive("test_skeletmodel:1", "Cladding_fin_outer_pattern") = False
Feature.IsActive("test_skeletmodel:1", "Cladding_LFIN_T1_outer") = False
Feature.IsActive("test_skeletmodel:1", "Cladding_RFIN_T1_outer") = False
Else If External_Cladding = True
Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer") = True
Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer_pattern") = True
Feature.IsActive("test_skeletmodel:1", "Cladding_fin_outer") = True
Feature.IsActive("test_skeletmodel:1", "Cladding_fin_outer_pattern") = True
Feature.IsActive("test_skeletmodel:1", "Cladding_LFIN_T1_outer") = True
Feature.IsActive("test_skeletmodel:1", "Cladding_RFIN_T1_outer") = True
'Check if tubes are even or odd
'If Tubes Mod 2 = 0 AndAlso Internal_Cladding = True
' Component.IsActive("Pattern_fin_slit_odd") = False
' Component.IsActive("Pattern_fin_odd") = False
' Component.IsActive("Pattern_fin_slit_even") = True
' Component.IsActive("Pattern_fin_even") = False
'Else If Tubes Mod 2 = 1 And Internal_Cladding = False
' Component.IsActive("Pattern_fin_slit_odd") = True
' Component.IsActive("Pattern_fin_slit_even") = False
' Component.IsActive("Pattern_fin_even") = True
'End If
'Opdatering af skeleton
iLogicVb.RunRule("test_skeletmodel:1", "update")
iLogicVb.UpdateWhenDone = TrueCode attached and and models. Ilogic placed in assembly.
Any suggestions?....
