Ilogic Boiler wall panel
- Mute
- Permalink
- Report
Hello
I am trying to build an ilogic the can parametric control a assembly of a wallpanel for a boiler. I am using a Skeletal modelling teknik to build the model and sync/update that into to the assembly.
But the catch is following:
1. If the Cladding is on , then the Slit Cutout shall be in every middle fines and if the Cladding is covering the Slit Cutout then the Slit Cutout has to cut through the cladding also.
2. If the Cladding is off, then the Slit Cutout shall be in every second middle fin if the Cladding is covering the Slit Cutout then the Slit Cutout has to cut through the cladding also.
The code:
'Parameter panel from skelet model Parameter("test_skeletmodel:1", "Totalheight") = Panelheight Parameter("test_skeletmodel:1", "pitch") = Pitch Parameter("test_skeletmodel:1", "tubes") = Tubes Parameter("test_skeletmodel:1", "Vertical_section")=Verticalsection Parameter("test_skeletmodel:1", "Tube_Bend_radius")=panelbendradius Parameter("test_skeletmodel:1", "deduction")=Deduction 'Parameter fin slit from skeletmodel Parameter("test_skeletmodel:1", "pitch_left_side") = Fin_width_left Parameter("test_skeletmodel:1", "pitch_right_side") = Fin_width_left Parameter("test_skeletmodel:1", "tubes") = Tubes 'Parameter tube material and certifikat iProperties.MaterialOfComponent("test_tube:1") = Tube_material 'Parameter tube Certifikat MultiValue.SetListInComponent("test_tube:1", "Cert", "EN10204-2.2", "EN10204-3.1", "EN10204-3.2") Parameter("test_tube:1", "Cert") = Tube_Material_Certifikat 'Parameter tube dimension data Parameter("test_skeletmodel:1", "Tubediameter") = pipediameter Parameter("test_skeletmodel:1", "Tube_wall_thickness") = pipethickness Parameter("test_skeletmodel:1", "Pipechamfer") = Tube_end_chamfer 'Chanfer on tubes yes or no If Tube_end_chamfer = False Feature.IsActive("test_skeletmodel:1", "Topchamfer_pipe") = False Feature.IsActive("test_skeletmodel:1", "bottomchamfer_pipe") = False Else If Tube_end_chamfer = True Feature.IsActive("test_skeletmodel:1", "Topchamfer_pipe") = True Feature.IsActive("test_skeletmodel:1", "bottomchamfer_pipe") = True End If 'Parameter fines on/off Parameter("test_skeletmodel:1", "Fin_thickness") = finthickness Parameter("test_skeletmodel:1", "fin_cutout") = fincutoutlength 'Parameter("Test_fin:1", "Fin_slit_YesNO") = Fin_slit_end 'If Fin_slit_end = False 'Feature.IsActive("Pattern_finslit_bottom") = False 'Feature.IsActive("Pattern_finslit_top") = False 'Feature.IsActive("Finslit_Cutout_bottom") = False 'Feature.IsActive("Finslit_Cutout_top") = False 'Else If Fin_slit_end = True 'Feature.IsActive("Pattern_finslit_bottom") = True 'Feature.IsActive("Pattern_finslit_top") = True 'Feature.IsActive("Finslit_Cutout_bottom") = True 'Feature.IsActive("Finslit_Cutout_top") = True 'End If 'Parameter fines configuration inconel yes/no 'If Internal_Cladding = True Or External_Cladding = True 'Parameter("Fin_slit_numbers") = Tubes - 1 'Parameter("Fin_Slit_pitch") = Pitch 'Parameter("Fin_slit_numbers") = Tubes-1 'Parameter("Fin_Slit_pitch") = Pitch 'Else If Internal_Cladding = False Or External_Cladding = False 'Parameter("Fin_slit_numbers") = Round((Tubes - 1) / 2) 'Parameter("Fin_Slit_pitch") = Pitch * 2 'Parameter("Fin_slit_numbers") = Round((Tubes - 1) / 2) 'Parameter("Fin_Slit_pitch") = Pitch * 2 'End If 'fin left side configuration If Leftside_fin_configuration = "None" Then Feature.IsActive("test_skeletmodel:1", "Chamfer1left") = False Feature.IsActive("test_skeletmodel:1", "Chamfer2left") = False Feature.IsActive("test_skeletmodel:1", "Chamfer3left") = False Else If Leftside_fin_configuration = "Chamfer1" Feature.IsActive("test_skeletmodel:1", "Chamfer1left") = True Feature.IsActive("test_skeletmodel:1", "Chamfer2left") = False Feature.IsActive("test_skeletmodel:1", "Chamfer3left") = False Else If Leftside_fin_configuration = "Chamfer2" Feature.IsActive("test_skeletmodel:1", "Chamfer1left") = False Feature.IsActive("test_skeletmodel:1", "Chamfer2left") = True Feature.IsActive("test_skeletmodel:1", "Chamfer3left") = False Else If Leftside_fin_configuration = "Chamfer3" Feature.IsActive("test_skeletmodel:1", "Chamfer1left") = False Feature.IsActive("test_skeletmodel:1", "Chamfer2left") = False Feature.IsActive("test_skeletmodel:1", "Chamfer3left") = True End If 'fin equal check 'If Equal_end_fins = True 'Then Leftside_fin_configuration = Rightside_fin_configuration And Rightside_fin_configuration = Leftside_fin_configuration 'Else If Equal_end_fins = False 'Then Leftside_fin_configuration = Leftside_fin_configuration And Rightside_fin_configuration = Rightside_fin_configuration 'End If 'fin right_side configuration If Rightside_fin_configuration = "None" Then Feature.IsActive("test_skeletmodel:1", "Chamfer1right") = False Feature.IsActive("test_skeletmodel:1", "Chamfer2right") = False Feature.IsActive("test_skeletmodel:1", "Chamfer3right") = False Else If Rightside_fin_configuration = "Chamfer1" Feature.IsActive("test_skeletmodel:1", "Chamfer1right") = True Feature.IsActive("test_skeletmodel:1", "Chamfer2right") = False Feature.IsActive("test_skeletmodel:1", "Chamfer3right") = False Else If Rightside_fin_configuration = "Chamfer2" Feature.IsActive("test_skeletmodel:1", "Chamfer1right") = False Feature.IsActive("test_skeletmodel:1", "Chamfer2right") = True Feature.IsActive("test_skeletmodel:1", "Chamfer3right") = False Else If Rightside_fin_configuration = "Chamfer3" Feature.IsActive("test_skeletmodel:1", "Chamfer1right") = False Feature.IsActive("test_skeletmodel:1", "Chamfer2right") = False Feature.IsActive("test_skeletmodel:1", "Chamfer3right") = True End If 'Parameter Cladding Parameter("Test_skeletmodel:1", "cladding_cutout") = Free_lenght_cladding 'Cladding on/off 'Inner Cladding If Internal_Cladding = False Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_inner") = False Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_inner:pattern") = False Feature.IsActive("test_skeletmodel:1", "Cladding_fin_inner") = False Feature.IsActive("test_skeletmodel:1", "Cladding_fin_inner_pattern") = False Feature.IsActive("test_skeletmodel:1", "Cladding_LFIN_T1_inner") = False Feature.IsActive("test_skeletmodel:1", "Cladding_RFIN_T1_inner") = False Else If Internal_Cladding = True Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_inner") = True Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_inner:pattern") = True Feature.IsActive("test_skeletmodel:1", "Cladding_fin_inner") = True Feature.IsActive("test_skeletmodel:1", "Cladding_fin_inner_pattern") = True Feature.IsActive("test_skeletmodel:1", "Cladding_LFIN_T1_inner") = True Feature.IsActive("test_skeletmodel:1", "Cladding_RFIN_T1_inner") = True End If 'Outer Cladding If External_Cladding = False Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer") = False Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer_pattern") = False Feature.IsActive("test_skeletmodel:1", "Cladding_fin_outer") = False Feature.IsActive("test_skeletmodel:1", "Cladding_fin_outer_pattern") = False Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer_pattern") = False Feature.IsActive("test_skeletmodel:1", "Cladding_LFIN_T1_outer") = False Feature.IsActive("test_skeletmodel:1", "Cladding_RFIN_T1_outer") = False Else If External_Cladding = True Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer") = True Feature.IsActive("test_skeletmodel:1", "Cladding_pipe_outer_pattern") = True Feature.IsActive("test_skeletmodel:1", "Cladding_fin_outer") = True Feature.IsActive("test_skeletmodel:1", "Cladding_fin_outer_pattern") = True Feature.IsActive("test_skeletmodel:1", "Cladding_LFIN_T1_outer") = True Feature.IsActive("test_skeletmodel:1", "Cladding_RFIN_T1_outer") = True End If 'Check if tubes are even or odd 'If Tubes Mod 2 = 0 AndAlso Internal_Cladding = True ' Component.IsActive("Pattern_fin_slit_odd") = False ' Component.IsActive("Pattern_fin_odd") = False ' Component.IsActive("Pattern_fin_slit_even") = True ' Component.IsActive("Pattern_fin_even") = False 'Else If Tubes Mod 2 = 1 And Internal_Cladding = False ' Component.IsActive("Pattern_fin_slit_odd") = True ' Component.IsActive("Pattern_fin_odd") = False ' Component.IsActive("Pattern_fin_slit_even") = False ' Component.IsActive("Pattern_fin_even") = True 'End If 'Opdatering af skeleton iLogicVb.RunRule("test_skeletmodel:1", "update") iLogicVb.UpdateWhenDone = True
Code attached and and models. Ilogic placed in assembly.
Any suggestions?....
