Ilogic - Batch dxf from Assembly
Message 1 of 33
Hi All,
I am having problems with a code.
I am trying to make a dxf from each sheet metal part in an assembly with ilogic: (I have cut and and paste diffrent codes from this forum in an poor atempt...)
Sub Main
Dim oApp As Inventor.Application = ThisApplication
Dim oAssy As Inventor.AssemblyDocument = oApp.ActiveDocument
For Each oSubDoc as Inventor.Document In oAssy.AllReferencedDocuments
If oSubDoc.DocumentType = kPartDocumentObject Then
Dim oPartPropset As Inventor.PropertySet = oSubDoc.PropertySets("Design Tracking Properties")
Dim oPartParam As Inventor.PropertySet = oSubDoc.PropertySets("Inventor User Defined Properties")
Dim oParameter As Parameter
For Each oParameter In oSubDoc.ComponentDefinition.Parameters
oParameter.ExposedAsProperty = True
Next oParameter
If oSubDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
DefaultChoice = True
CADline()
Else
' here is code for normal parts
Next
oAssy = Nothing
oApp = Nothing
End Sub
Public Sub CADline()
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=R12&OuterProfileLayer=IV_INTERIOR_PROFILES"
Dim sFname As String
sFname = oDoc.FullFileName
sFname = Left$(sFname, Len(sFname) - 3) & "dxf"
oCompDef.DataIO.WriteDataToFile( sOut, sFname)
Dim oSMDef As SheetMetalComponentDefinition
oSMDef = oDoc.ComponentDefinition
oSMDef.FlatPattern.ExitEdit
End Sub
Replies (32)
Message 21 of 33
When I try using your code it pops up with an error saying that I need to add a job# to iproperties.  I tried adding a custom one in the BOM but that didn't work.  When I go to the Iproperties I don't see anything labeled as the job # could you clarify what I need to do here to make it work.
Message 22 of 33
kevinv
Good catch.  We use the iProperties “Project” for job number.  That number is used to sort the DXFs into job folders on our production server.  Feel free to modify the code to remove the need for Job # and locate the DXFs wherever you want them.
edit: based on your question I am guessing that you are new to iLogic?  Let me know if you need help modifying the code to place the DXF files where you want them.
BTW - we still use this code all the time. I have written over 40 iLogic rules for the company now, all of them are helpful but none as helpful as this one!
Message 23 of 33
You're right I am new to this. Is there any way you could make it create a new folder in the same location as the dxf? I appreciate your offer to help.
Message 24 of 33
kevinv
No Problem, happy to help.  I am not sure I am following your question though.  The code will create a new folder for your DXFs to land in based on how you define New_Folder_Path.  The code example from reply 17 in this thread places the DXFs on my G: drive in a folder that might not exist yet (based on possible new job #).  That folder is created before the DXFs are made.
So I think it is doing what you want but I am guessing you will need the path fixed?
Please explain a little further what you are looking for.
Message 25 of 33
Sorry I didn't understand that the code already made a folder.  I would just like to have it put the folder in the same place as the assembly if that's possible. As well as no longer needing the job#.  Thanks again for your help.
Message 26 of 33
kevinv
Sorry for the confusion, I think I understand what you want now.  This will add the DXF Files to gauge folders right where the assembly is saved.  Hope this helps:
edit: just make sure you don't have any characters in the names of your Sheet Metal Rules that can't be in file or folder names.  I did, so this code will do a replace for "/" or inch marks (").  Any others will cause errors and you will have to do a Replace on those as well to get rid of the errors.
Sub Main()
    Dim New_Folder_Path As String = ThisDoc.Path
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
'    Dim Job_confirm As String
'    Job_confirm = MsgBox ("Sending Files to DXF Folder " & iProperties.Value("Project", "Project"),vbOKCancel, "Confirm Job #")
'    If Job_confirm = "2" Then Exit Sub
    My.Computer.FileSystem.CreateDirectory(New_Folder_Path)
    'Ask user for REV level
    Dim Rev_Level As String = ""
    Rev_Level = InputBox ("Enter Rev Level","Creating DXF files For Entire Assembly")
    Dim Count_up As Integer = 0
    Dim Gauge_Folders(12) As String
    Dim Ga As String
    Dim doc As document
    For Each doc In oAsmDoc.AllReferencedDocuments
        If doc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
            Dim oSheetMetalCompDef As SheetMetalComponentDefinition
            oSheetMetalCompDef = doc.ComponentDefinition
            Ga = oSheetMetalCompDef.ActiveSheetMetalStyle.Name
            Ga = Replace(Ga, "/", "_")
            Ga = Replace(Ga, Chr(34), "")
            If UBound(Filter(Gauge_Folders, Ga)) > -1 Then
            Else
                Gauge_Folders(Count_up) = Ga
                Gauge_Path = New_Folder_Path & "\" & Ga
                My.Computer.FileSystem.CreateDirectory(Gauge_Path)
    Next
    ReDim Preserve Gauge_Folders(Count_up)
    For i = LBound(Gauge_Folders) To UBound(Gauge_Folders)
        msg = msg & Gauge_Folders(i) & vbNewLine
    Next i
    MsgBox ("Adding DXF files to Folders:" & vbNewLine & vbNewLine & msg, ,"Gauges Found")
    Count_up = 0
            Call Make_DXF(doc, Rev_Level, New_Folder_Path)
        Count_up = Count_up + 1
    Next
MsgBox("DXF Export Complete",,"All Done")
End Sub
Sub Make_DXF(doc As Document, Rev_L As String, File_Location As String)
    Dim GA_Adder As String = oSheetMetalCompDef.ActiveSheetMetalStyle.Name
    GA_Adder = Replace(GA_Adder, "/", "_")
    GA_Adder = Replace(GA_Adder, Chr(34), "")
    Dim Part_Name As String = doc.DisplayName
    Dim TestPos As Integer = 0
    'checking for parts that don't have flat pattern and telling user what parts are skipped for lack of flat pattern
    part = doc.ComponentDefinition.Document.FullDocumentName
    ' Create flat pattern if none
    If Not oSheetMetalCompDef.HasFlatPattern() Then
        ' Open document
        openDoc = ThisApplication.Documents.Open(part,False)
        ' Unfold part
        oSheetMetalCompDef.Unfold()
        ' Exit flat pattern
        oSheetMetalCompDef.FlatPattern.ExitEdit()
        ' Close document
        openDoc.Close()
        Dim Rev_Adder As String = ""
        If Rev_L <> "" Then Rev_Adder = " REV " & Rev_L
        TestPos = InStr(1, Part_Name, ".")
        If TestPos <> 0 Then
            Part_Name = Left(Part_Name, InStr(Part_Name, ".")-1)
        Dim New_Name As String = Part_Name
'        '*******************remove line below to remove gauge from file name***********
        New_Name = GA_Adder & " " & New_Name
'        '*******************/remove line above to remove gauge from file name**********
        Dim nameandpath As String = File_Location & "\" & GA_Adder & "\" & New_Name & Rev_Adder & ".dxf"
        Dim oDataIO As DataIO = doc.ComponentDefinition.DataIO
        oDataIO.WriteDataToFile("FLAT PATTERN DXF?AcadVersion=R12&RebaseGeometry=True&SimplifySpline=True&InteriorProfilesLayer=IV_INTERIOR_PROFILES&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL&SplineToleranceDouble=0.01",nameandpath)
End Sub
Message 27 of 33
This sounds like it's exactly like what I need. I'll try it when I get to work. Thanks for all your help.
Message 28 of 33
kevinv
New code that works a bit different.
This creates all DXFs within an assembly that have the Vendor iProperties set to "Laser"
The DXF Files are located in subfolders at the location of the saved assembly file sorted by a Parameter named "Thickness" and Material type for each part.
Sub Main()
    Dim Ga As String
    Dim doc As Document
	Dim R_Part As String
	Dim oMaterial As Material
			R_Part = doc.DisplayName
			oMaterial = doc.ComponentDefinition.Material
			Gauge_Path = New_Folder_Path & "\" & Parameter(R_Part, "Thickness") & " " & oMaterial.Name
			If iProperties.Value(R_Part, "Project", "Vendor") = "Laser" Then
				Try
				Catch
				End Try
            	Call Make_DXF(doc, Rev_Level, Gauge_Path)
    Next
End Sub
        ' Open document
        ' Unfold part
        ' Exit flat pattern
        ' Close document
        openDoc.Close()
        Dim nameandpath As String = File_Location & "\" & New_Name & Rev_Adder & ".dxf"
End Sub
Message 29 of 33
When I tried to run this it popped up with an error window saying
"Error in rule: Create DXF Sort Thickness Material, in document: "Assembly Name"
Parameter: The component named "File Name of a Sheet Metal Part" was not found."
Message 30 of 33
Sorry for asking, is it possible to save all the Dxf file in 2010 version?
Message 31 of 33
kevinv
Yes, you sure can look for this line near the bottom:
change AcadVersion=R12 to AcadVersion=2010
I just tested it, that is all you need to do.
Message 32 of 33
ktsaleej
Plate and sheet development
In here you can generate AutoLISP(.lsp) program to draw the development of geometric shapes in AutoCAD. This drawing you can directly transfer to your cnc plate cutting machines to cut the plate. Just select shape which you want to draw and fill the form, You can generate your AutoLISP(.lsp) program.
Development
Message 33 of 33
ktsaleej
Development
