iLogic batch application
psw1125
psw1125
If I write in iLogic in Inventor, I can edit one part.
There are about 100 files with the same rule.
Is there a way to apply them collectively instead of individually applying them one by one?
A.Acheson
Yes there is multiple ways.
It will all depend on where your files are located.
Questions are as follows:
  • What is the rule doing, updating iproperties?
  • Do you want to point to a windows folder path and run all the rules in those files?
  • Are all the ilogic rules internal to the document?
  • Are the files assemblies or parts or both?
  • Can you easily identify the files by file name, iproperty etc, if they are in amongst other files?
You can create a rule to look at a directory of files, open each one and run the rule, save and close once you know the workflow you want.
Regards
Alan
el_jefe_de_steak
Are you trying to make changes to an existing iLogic rule in all those parts?
Or, are you wanting to use one iLogic rule to make changes in more than one part?
fidel.makatiaD5W7V
Hi @psw1125 you can also read about batch logic from inventor docs
Inventor 2022 Help | Batch update part number to filname | Autodesk
Inventor 2022 Help | Batch print in numerical order | Autodesk
Inventor 2022 Help | Close a different open drawing within iLogic - batch export drawing pdf etc | A...
Fidel Makatia
Developer Advocate
href=https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-0BD48573-7193-4285-87B7-6727555D053E rel= "noopener noreferrer">Inventor 2022 Documentation |
