iLogic, Assemblies and part parameter values
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey
i do try to avoid iLogic where possible but sometimes there is a need. In my case, model states and the relationship between assembly values & part values. To be honest, Model states shouldnt really come into this but im using them so will reference them.
In my assembly, i have a custom iProperty field called "P_Qty"
in my part, i have a Parameter called "Qty"
i want to change the parameter in the part when the iProperty is changed in the assembly.
iLogic
Parameter.Value("GL:1", "QTY") = iProperties.Value("Custom", "P_Qty")
ive also tried
Parameter("GL:1", "QTY") = iProperties.Value("Custom", "P_Qty")
which is basically saying or at least it should be-
Change the value of the parameter named "QTY" in occurrence "GL:1" to the value of the custom iProperty "P_Qty" in the assembly
when i run this, i get an error
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Parameter.set_Expression(String )
at iLogic.ParamDynamicFinder.SetParamValue(Parameter param, Object value, Boolean doUpdate)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Even if i change to a static number, it doesnt work..
Parameter.Value("GL:1", "QTY") = 1
what am i missing? The part is in the assembly and im trying to run this from the assembly iLogic
thanks
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
