ilogic and model parameters out of sync
I have an assembly with parameters:
mass
mass_engr = ceil(mass / 0.5 kg) * 0.5 kg [exported]
ilogic rule:
iLogicVb.UpdateWhenDone = True
'mass = iProperties.Mass Parameter("mass") = iProperties.Mass MessageBox.Show(CStr(mass) & "," & CStr(mass_engr) & "," & iProperties.Value("Custom", "mass_engr"), "Title") MessageBox.Show(CStr(Parameter("mass")) & "," & CStr(Parameter("mass_engr")) & "," & iProperties.Value("Custom", "mass_engr"), "Title")
mass_prop = iProperties.Value("Custom", "mass_engr")
Dim part = "COVER PLATE"
iProperties.Value(part, "Custom", "mass_engr") = mass_prop
Q1
I have to use [ Parameter("mass") = ] not [ mass = ] otherwise "mass_engr" and the exported custom iproperty don't update while the rule is running (used later by the rule).
Is there any way to force these to update if I use [ mass = ] ?
Q2
If I use [ Parameter("mass") = ] so that the others update, then later directly using "mass" and "mass_engr" still gives the old non-updated values.
So I need to get the new values with Parameter("mass") and Parameter("mass_engr")
(the 1st message box gives old values, the 2nd gives updated values)
Is there anyway to "sync" parameters with the rule so that "mass" etc. give the new values?
